Adding wood trim to existing vinyl
ryno | Posted in General Discussion on July 29, 2009 10:49am
Here is my situation.  I have vinyl on my house with aluminum clad windows.  I was wondering if I could cut back the vinyl to add a wider trim board around my windows providing a more colonial look.  They look so terrible and lifeless.
Basically I was thinking of cutting my siding back 3.5 inches or so, then in stalling a 3/4″ thick vinyl block between the window and the siding.  Install j-channel up to the blocking and then 4.5″  cedar trim over the blocking to hid the j-channel.  Does that make sense?  Would it look silly if my trim was “floating” over my vinyl siding?
  1. dcarroll3000 | Jul 30, 2009 01:08am | #1
    Consider this a bumb, perhaps Piffin will be along. I'd space the trim out so that the
    siding goes underneath it rather than using J-channel.  If you search the articles,
    I think Mike Guertin has one called "Vinyl Siding Done Right" that shows some tricks.
    best of luck
    -d
  2. florida | Jul 30, 2009 02:00am | #2
    Yes, this is do-able. What we do is plow a 3/4" mortise on one edge of a piece of Azek pvc trim, cut back the vinyl with a fine toothed circular saw blade and install the Azek over the cut edge of vinyl. It's messy but looks much nicer than the vinyl trim.
    1. ryno | Jul 30, 2009 03:32pm | #3
      Thanks for the ideas!
  3. LIVEONSAWDUST | Jul 30, 2009 05:07pm | #4
    I have done this a few times, but skip the J channell. It works fine on the sides and bottom, but at the top you will have to fabricate somes sort of flashing that goes UNDER the siding and OVER the trim. I have modified standard aluminum facia for this flashing.
    I have also used this detail on some new construction, as I think that J channell is the ugliest part of vinyl siding
    1. ryno | Jul 30, 2009 05:15pm | #5
      I was pondering how I would flash the top and sides to shed water.  I was thinking adhesive water barrier.
      I too hate j-channel.  I think it is what ruins most vinyl siding jobs.
