Adhesive for vinyl sheet flooring
jimmiem | Posted in General Discussion on February 28, 2010 02:52am
I had a vinyl sheet floor installed.  There is a small section against a cabinet that is lifting.  What’s the best adhesive for the job?  It’s not at a corner so there is not a lot of room to get under the edge.Would putting heat on the area to re-melt the adhesive and then weighting it down work?  I have seen this done on a laminate counter top.
Thank you
  1. wane | Mar 01, 2010 08:21am | #1
    a little more info may be required, if this was recently done get the installer back in to fix.  If it Is an edge that was not secured, then it should have been covered by 1/4 round, or a transition strip.  If it's a seam then there is a solvent available that is transparent and melts the edges together .. but definetly not heat!
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
