Advice–covering windows while painting
prout35 | Posted in General Discussion on July 31, 2006 08:16am
We have a log house. We put a protective coating on the outside before windows were installed using a garden sprayer to flow on the product. We are now ready for a recoat and the windows are installed.
My question: is there an easier way to protect the windows other than taping plastic over them?
Thank you.
  1. hellcatt200 | Jul 31, 2006 09:35pm | #1
    not really. either cover em or remove em is all i can offer for advice. good luck
  2. saulgood | Aug 01, 2006 11:40am | #2
    Since a garden sprayer involves such little pressure, I would be thinking about using a painter's shield - basically a 3' wide lightweight spatula (In the right hands, I've seen these used with airless sprayers to "two tone" a livingroom ceiling/walls).
    Sure, some spray might get around the edges, but you can get it off with spray bottles and rags.
    If many windows are the same, you could even get creative and make a fitted shield out of some non absorptive, lightweight material mounted it to a handle or a pole that could be held by an assistant. You could edge it with weatherstripping to "cup" the frame while you work around it. You'd have to wipe it clean often. Painters often wrap their shield with masking paper and pull it off when it gets too soggy.
    1. FastEddie | Aug 01, 2006 03:26pm | #3
      For the "custom shield" you could cut a piece of rigid blue foam insulation.
      1. saulgood | Aug 01, 2006 04:47pm | #4
        I like it! Is that stuff "closed cell", or "open"? I'm picturing the thick, stiff material with non pourous backing. You might have to tape the edges to keep it from getting heavy with sealer. For a pole attachment you could glue one of those "swiffer" mopps to the center, or use a pole sanding rig.
        1. FastEddie | Aug 01, 2006 06:22pm | #5
          Is it open or closed cell?  Yes.  Whatever they have at the home center.
          Might have to be concerned with the sprayed material being compatible with the foam.  Maybe foil faced insulation with metal foil used to seal the cut edges would be better.
  3. bustaduke | Aug 02, 2006 03:22am | #6
    Why not use a product that's made to protect windows.
    http://www.finishguard.com/windowandglass.html
    busta
  4. piko | Aug 02, 2006 03:57am | #7
    Some people recommend Vaseline smeared over. Sure, there's a lot of window to deal with (and clean up after), so instead I'd attach plastic over the 'field' of the window, then use 6" self-adhesive masking paper to cover the frames and edges.
    All the best...
    To those who know - this may be obvious. To those who don't - I hope I've helped.
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
