advice handling/ transporting granite
well being the proverbial tightwad, i’ve decided to tackle a large granite countertop myself. plan is to buy the slabs and put them on a trailer, travel 200 miles and drop them off at a shop with a water jet saw. have them cut it ,load it up again with 2 sink holes cut in them [i cringe at moving them with a 3″ pc across the front] bring them into the house and set them then polish the edges. thats the plan!any sugesttions on how to move the slabs down the highway, and then after they are cut? i’m trying to figure out a a frame type carrier to mount on the trailer, or do you think they can lay flat? any easy way to move it in the house without snapping it? i know the easy way would be to hire it fabracated, but what fun would that be???? lol thanks larry
Transport them upright on edge in a cradle with padding -- old carpet works well. Think 'A' frame -- the way they transport glass.
Ask the shop to save the sink cutout pieces, put them back in position with dobs of sheetrock mud -- that'll help to support the front and back edges of the cutout and you can easily cut them free afterwards with a padsaw.
Carry them in the cradle -- upright and on edge at all times.
One way to make it idiot-proof is to design the cabinet so that you can stick a sheet of 3/4" mdf permanently to the back of the granite [neutral-cure silicone will do that] as soon as you get it from the shop -- still stick the cut-outs back though with the sheetrock mud.
IanDG
i like that idea about bonding mdf to the back except i have already got my cabinets built and i made the tops solid so they could help support the granite. i've glued and nailed them so that won't work. what about if a guy hot glued a 2x 4 along the front and back to help support while placing it. do you think you could get the hot glue off the surface? thanks for the info larry
I don't see why it shouldn't work -- the glue should come off easily enough because it's not going to penetrate the granite.
IanDG
Clamps are more commonly used than hot glue. You have to arrange the support system to clear the clamps though.
Padsaw ... not a term I'm familiar with.
I agree on the plywood. Even a sheet of 1/4" would help.
What about designing it with a joint centered on the sink?
Whenever you are asked if you can do a job, tell'em "Certainly, I can!" Then get busy and find out how to do it. T. Roosevelt
Edited 10/11/2004 8:36 pm ET by Ed Hilton
it kinda goes against my thought pattern of taking 1 pc and making it 2. but the more i think about it, it don't sound to bad, all that would really show is 2.5" fine line grouted and siliconed. and i think the risk of breaking it would be slight.[unless you hit one of the thin legs sticking off] thanks i'll chew on this idea a little. larry
I know you have them because I've seen them in HD but I don't know what your name for them is.
They look like a fish-filleting knife with teeth.
IanDG
Ok ... like a keyhole saw.
Dang foreigners. Next thing you know, they'll be using funny words for truck ... elevator ... umbrella ... baby carriage ... simple, common stuff everybody understands.
Edited 10/12/2004 7:28 am ET by Ed Hilton
Just put in some granite tops. The thin strips on both edges of the sink were grooved and steel rods epoxyed into the grooves.. Looked bullit proof. All movement of the slabs was when they were vertical. Only horiz was when final tip to the cabs. Might ask the fabricators for some tips...
drop in or undermount sink? if it's a drop in... man i think i'd cut or have someone come cut the sink hole in place... if it's a drop in sink it wouldn't be a big deal with a diamond blade...
i do know this... if you crack one... it ain't the cheap way to go if ya have to buy 2...
pony
i'll be going with a undermount sink,i tossed around leaving about 4" uncut on each side,then when in place using a diamond blade to cut it out. i think if a guy breaks it thru the sink opening they have some kinda epoxy to glue it back, but i don't want to find out! larry
Yer not gonna save any money!!!
Mr T
I can't afford to be affordable anymore
maybe not ,but i gotta give it a shot. fabracator wants 45. sq ft x120.= 5,500 i can buy the slabs for 8.25 sq ft x120 plus 4-500 on the water jet. i'm hoping to come in around 2k total after i buy some polishing supplies.but as most things go there will be some surprises. larry
on edge.
then on edge ...
then on edge.
oh yeah ... carry it on edge too.
and plan on help. All the stone shops have a coupla thick short guys ...
not sure if they started the day short ... but they are by the time they load ... drive it ... unload it .... then install it.
lets see hows this goes-on edge-on edge-on edge,right? lol larry
So you want to be frugal!! Why not just leave the edges rough? Use a wet saw to cut on site to size. You could soften the edges with epoxy applied with a brush. Some triming can be done with a brick hammer or a torch to give a flame edge. Get a scrape piece and have a go! But you will need some tough guys to move it around.
I have always seen them delivered with the cut outs incomplete, they make the final cuts onsite.
