Advice need for patio slab pour. Please
MBaybut | Posted in Construction Techniques on April 6, 2010 08:42am
Hi,
I’m doing a small patio at the front of my house but not 100% sure on how to do it. The parts that I’m a bit fuzzy on is how to do the screeding when one of the edges is directly against the wall. Won’t that prevent the screed from being able to go back and forth? Also, should I pin the slab to the house and exsisting driveway? Any other tips or help truely appreciated.
Mike.
ps, I’m having the concrete delivered, if that’s relevant.
  1. davidmeiland | Apr 06, 2010 09:58am | #1
    I would use metal stakes
    to set up a screed along the house (parallel to the existing slab). I would set the screed so that it will not be embedded in the pour, but above it. Then, rig up your screed board with a riser of some sort on one end.... the riser rides on top of the elevated screed while striking the concrete at the right level. As soon as you can get on the new pour go out there and remove the screed and the stakes, and fill the holes with mud you set aside in a wheelbarrow out of the sun. It is useful to have some scraps of foam insulation board... make stepping stones to get yourself out on the fresh pour after it sets up.
    I would not pin to the house, I would definitely pin to the existing driveway.... #3 rebar and epoxy.
    1. MBaybut | Apr 06, 2010 10:52am | #4
      That all makes sense, thanks so much. And luckly enough, I have some scraps of foam from a job I finished last week.
      Mike
  2. calvin | Apr 06, 2010 10:28am | #2
    Pour
    Use grade stakes and/or a chalk line on the wall to set up a "screed line" of concrete.  Pound in the stakes once you get that strip of concrete right.
    Use that strip of concrete as your guide to pull back.  You have to be careful to maintain that strip level, don't dig in and pull it out along with the rest.
    Is that  EFIS stucco on that house, buried in the dirt?  Is the house wood frame or masonry with EFIS over if?
    Are you digging out that area and putting down stone?
    1. MBaybut | Apr 06, 2010 10:48am | #3
      It is stucco, not sure what type. over block.  I was just going to dig down 4" and compact dirt. Then pour the concrete. I'll be laying thin pavers on top later in the year.
      Thanks,
      Mike
  3. woodturner9 | Apr 06, 2010 05:21pm | #5
    No.  If the substrate is not properly prepared or the slab fails for some other reason, letting it "float" relative to the house and driveway will keep the slab from damaging them if it fails.
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
