Advice on Repair to Modified Main Beam in Bi-Level House
As an addendum, I actually was digging around more and do now see there is a Microlam option which is the exact 9 1/4" height. I had been looking at the VERSA-LAM options which have a 9 1/2" height. The versa-lam seems to be more available in my area but I can see about the microlam. Still kind of wondering though if the extra 1/2" of height could be a good thing in terms of making up for what appears to be some "squash" loss of height in the original beam.
You are correct with the term of sistering. I would do as you are planning, might as well use the existing floor joists that are there instead of throwing in a dumpster. Also, more wood typically means more strength. If you remove the old joists it will definitely mess with the subfloor which in turn will effect the finish floor. The LAM will not shrink or squash like a 2x10. The new 2x10’s will shrink some, so I like to keep those a little higher than the beam. A steel flitch beam might be a good option as well, but confirm w/ your engineer. The engineer will need to sign off on whatever you decide to do.
