Advice on shed foundation
drew725 | Posted in Construction Techniques on April 13, 2011 12:41pm
Going to be building a 17’x20′ shed in Norther Virginia.  Was planning on building the foundation using solid concrete blocks set on 4″ of gravel.  But,….have read a couple of articles that says concrete block foundations work for small to mid sized sheds, and anything over 200 sq/ft should use a post/pier foundation.  I’d rather keep to the solid concrete block to keep it simple and I already have the block.  Thoughts?
For the rest of the shed flooring I’m looking at setting 4×6 PT beams on the block.  The floor would be 2×6 PT joists 12″ OC sitting on the block.  Floor sheathing will be two layers of 3/4″ OSB.
Thanks,
  1. DanH | Apr 13, 2011 06:36am | #1
    Depends on the soil and drainage.  On well-drained, stable soil you should be fine.
    You do need to tie things together well, or otherwise the shed will slowly creep off the block.
  2. [email protected] | Apr 13, 2011 02:18pm | #2
    Permit Required?
    In most locations you need a building permit for anything over 200-sf.  That is why at 200-sf you have to have a real foundation.
    So, I'd ask the AHJ, what the requirements are. They may have minimum standards.
  3. junkhound | Apr 13, 2011 02:20pm | #3
    If no permit is needed, I just throw a few old railroad ties on the ground and go from there.
    Have just used old car wheels filled with mud also.
Outdoor Lighting
  • A Grand Rescue on the Coast
