Advice on tile baseboard
carlmccarty | Posted in General Discussion on August 8, 2008 10:00am
I’ve just finished setting the floor tile in th bath. The wall is tiled and grouted. After I grout the floor, I am planning on using the preformed tile baseboard. Should I be setting the baseboard in with thinset and then grouting the joints like everything else, or should I use silicone to bond the base to the floor and wall and between the joints?
Thanks.
  1. DaveRicheson | Aug 08, 2008 01:09pm | #1
    Thinset or mastic.
    Butter the back of each piece and place it on the wall. Grout the vertical joints and caulk the joint that intersect the floor tile.
  2. Hackinatit | Aug 08, 2008 01:30pm | #2
    I've used silicone with good success, but thinset or mastic will be better for the long run.
    A La Carte Government funding... the real democracy.
Outdoor Lighting
