Hello,
I recently added an upstairs bedroom and I’m planning to add another bedroom and a full bath but I was hoping you could offer advice on the following topics;
1) The new bedroom is approx 336′ and is tied into the existing 3-ton CH/A system which already services approx 1850′ on the lower level. This system is 13 yrs old and requires service each summer so I was planning to replace it with a larger unit with the addition of the new rooms which will add another 450′ or so. I was thinking of a single large unit partly because the stairwell leaves a continuous opening between the upper and lower levels anyway. However, a portion of the cielings of each of the upper rooms is on the direct underside of the 2×6 rafters with the deck and shingles on the other side. My question is, would it be better cost and efficiency-wise to have a large unit handling the entire house or smaller zoned units for each level?
2) The new bathroom will be directly over a bath on the lower level and I was planning to use the same layout so the plumbing would line up. However, the lower level is on a slab and I don’t think I can tie the waste lines in so I was planning to run them between the 2×6 ceiling joists to the outside of the house and then down through a built box of some kind and into the septic system. This would mean a run of approximately 20′ level across the cieling before the drop on the outside. Will this work and is there a better way to do this? Also, will there be any problems with water pressure in the upper level bathroom?
Hello,
I recently added an upstairs bedroom and I'm planning to add another bedroom and a full bath but I was hoping you could offer advice on the following topics;
1) The new bedroom is approx 336' and is tied into the existing 3-ton CH/A system which already services approx 1850' on the lower level. This system is 13 yrs old and requires service each summer so I was planning to replace it with a larger unit with the addition of the new rooms which will add another 450' or so. I was thinking of a single large unit partly because the stairwell leaves a continuous opening between the upper and lower levels anyway. However, a portion of the cielings of each of the upper rooms is on the direct underside of the 2x6 rafters with the deck and shingles on the other side. My question is, would it be better cost and efficiency-wise to have a large unit handling the entire house or smaller zoned units for each level?
2) The new bathroom will be directly over a bath on the lower level and I was planning to use the same layout so the plumbing would line up. However, the lower level is on a slab and I don't think I can tie the waste lines in so I was planning to run them between the 2x6 ceiling joists to the outside of the house and then down through a built box of some kind and into the septic system. This would mean a run of approximately 20' level across the cieling before the drop on the outside. Will this work and is there a better way to do this? Also, will there be any problems with water pressure in the upper level bathroom?
