agressive sander & vacuum !?
johnharkins | Posted in Tools for Home Building on July 16, 2008 04:56am
O K one & all
I’m renovating what could be a 108 yr olde porch
the deck is beautiful 5 / 4 X 3 plus “s VG fir and there are numerous coats of paint aboard – alligator type & areas I’ll be taking down to clear wood
went to the store thinking I would retire my 30 plus yr olde Rockwell 3 X 21 and get a new belt sander but arrived upon a 7″ grinder & bought the sanding adaptor & that thing rocks but either the EPA is gonna come or they’ll be kicking me out of the hood due to unbelievable dusting of local environs
I have finest Bosch & good Porter Cable to hook up to my vacuum but those do not cut the mustard like this unit
Any ideas on what could deliver besides floor edger ?
Festool or their brethren have something of this ilk?
many thanks, john
    FatRoman | Jul 16, 2008 05:06am | #1
    You can try this Festool rotary sander:
    http://www.mcfeelys.com/product/570738/RAS-11504-E-Rotary-Sander
    Apparently it's the cats pajamas in going through multi-layered paint, but it's not as great at dust containment as their other sanders.
    If you want almost dust free sanding, this is what you want to be driving:
    http://www.mcfeelys.com/product/571594/Festool-Rotex-150-FEQ-Dual-Mode-Sander
    Don't go without the vac system though, that's really what makes these shine.
    'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
  2. RW | Jul 16, 2008 05:07am | #2
    they do
    Probably closest to what you're looking for would be the 6" rotex, and the CT22 vac. Its the smallest one that comes HEPA. And they have a wide paper selection to fit.
    Real trucks dont have sparkplugs
    1. johnharkins | Jul 16, 2008 07:27am | #3
      and thanks RW & Fatroman
      I'll be doing my research
  3. cynwyd | Jul 16, 2008 08:05am | #4
    I'd use  Silent Stripper and follow up with a direct drive Bosch RO sander then a AEG RO sander.
    The  silent stripper goes quickly on flat work like your floor.
    Or after the Silent Stripper I'd rent a U-Sand.
    Edited 7/16/2008 1:07 am ET by cynwyd
    Jeff_Clarke | Jul 16, 2008 08:16am | #5
    In our town, unless you were using the paint shaver or similar (Metabo) with vacuum attachment it would be illegal to remove (presumably lead-bearing paint) that way.
  5. davidmeiland | Jul 16, 2008 08:58am | #6
    OFF TOPIC--John, you emailed a while back about insurance. The email you have attached to your Breaktime profile is nonworking. If you're still interested in my carrier get ahold of me.
    1. johnharkins | Jul 16, 2008 06:26pm | #7
      thanks all for input
      leaning Festool & probably 4 1/2 "
      seems a bit more dedicated to my use and pricing better than that 6" but do like the notion that the bigger one will be more useful in more varied applications
      Can't get around silent stripper at this point & the u sand tool just does not have the aggression w/ double G i'm looking for although I've only used it on white oak
      and Jeff that is why I'm asking
      David look in your mailCarry on all - off to permit dept , John
Fast, Accurate Wall Framing
