Air Conditioner Evaporator Coil Condensation Drips On To Filter.
JD_Clampett | Posted in General Discussion on July 17, 2021 09:33am
I have a Trane air conditioner model TWG030A140B1.
The air handler has a single evaporator coil mounted vertically at about a 45 degree slant.
As condensation builds during normal use, the water will trickle down the fins and into the catch pan and the out the drain pipe.
Water drains great, no issue there.
The issue is that as some of the water trickles about half way down the fins it then drips straight off of the coil and onto the filter.
Eventually the water will pass thru the filter and collect on the floor.
I’ve cleaned the evaporator several times with a garden hose along with different store bought cleaners as well as dawn dish soap with a soft bristle brush.
Still have the same issue. Nothing works.
Fins are in great shape, nothing bent up. Nothing plugged up. I can shine a flashlight thru the coil.
Again, this is not a drain problem, catch pan problem or trap problem.
Seems like a surface tension problem.
Any suggestions?
  1. creed73 | Sep 11, 2021 03:15pm | #1
    I’m am having the same issue.
    Condensation drips from the coils directly on to the filter below. The filter will be come saturated and begin getting sucked into the unit after about 10 - 14 days.
    We have cleaned the outside of the coils with a spray on foaming cleaner and soft brush. Then rinsed thoroughly. I can see light through the coils when a light is shined through with no issue.
Outdoor Lighting
