I’ve lived in my house for 9 yrs. and have never had my air ducts cleaned because I have a
large air furnace filter (Safe Guard) which I replace every year. Is this sufficient to keep the ducts clean?
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
Hard to say. I've seen reasonably clean ducts after many, many years of service. What type of filter are you using? Is it pleated?
Yes it is pleated. Brand is Space Guard model 2200.
You can open up the duct system in several easily-accessed places to have a look.
Pull off a couple of supply registers and one or two return grilles that are farthest from the air handler and have a look. Lay a flashlight in the duct and hold a small mirror so you can see back along the length of the duct.
Thanks, will try.
I always thought duct cleaning was a scam. D-wife hounded me enough that I gave in an had the ducts cleaned. I got suggestions as to who to use from a number of HVAC guys I trusted. They got a lot more material out of the ducts than I would of believed.
I always thought duct cleaning was a scam...
So does that mean that you now believe it to NOT be a scam?
I'll admit that I find it hard to believe that dust that's adhered to the inside of the ductwork (and, in fact, requires a powered brush to be removed) can cause a problem with indoor air quality. Now, once it's disturbed and becomes airborne, it may indeed be a problem, but hopefully the newly liberated dust will be trapped by the filter or be re-adhered to the inside of the ductwork.
I've always though it to be, if not a scam, a poor way to spend money. What little dust is sitting on the bottoms of ducts is stationary and not hurting anything. Anything that gets airborne is handled by the filters.But I suppose I shouldn't tell others how to spend their loot. If they want to support this business then so be it....Scott.
It used to make sense, back when people heated with coal and maybe ran a smoky fireplace a lot. Not so much anymore.
Funny thing is though, that the whole Duct Cleaning frenzy seems to have taken off in the last twenty years (at least around here), long after people stopped using coal.Scott.
Yeah, it's sold as an allergy fighting tactic, among other things. Might be helpful in that regard in homes that have had (in the past) a bad cockroach infestation, but probably not otherwise.
Hi, I have the electronic air cleaners and metal mesh filters.
A few years ago I bought the blue plastic like 1" thick filer mesh, opened all returns(1 or 2 in every room, in the wall), and cut a snug pc to fill the stud cavity. Then 1 x year I open and vacuum them. It does amaze me what they catch before it gets in the duct.
Its also seem to be a way to see what returns are doing the mosr work. its cheap, and hopefully will keep my ducts cleaner.
Good luck!
And the added restriction from the filters does this:
Restricts airflow back to the furnace, reducing efficiency in the best case. Equipment damage is possible in the worst case.
Now that the air can't be easily pulled through the relatively unrestrictive grille opening, air is sucked in from every single other opening in the duct system in an attempt to make up the difference... including the knockout on the bottom of the furnace if it hasn't been taped shut.
If your duct systrem is in the attic, fiberglass particles are one thing being sucked in... plus hot/cold air depending on the season.
If the return system is in the walls, using the stud and joist bays, you are sucking in dust there and increasing the possibility of air infiltration if the floor joist bay connects to the rim joist and isn't sealed well.
Typical residential duct systems are not sealed well, if at all.
Controlled air leakage is better than uncontrolled air leakage.
$.02
yep, all filters restrict, its a balance betwen the two. I have 2 units in a single floor house, nbothe in basement, and well sealed and insulated, so I look at the dust that I catch and deem the restriction an acceptable cost (more power ect, BUT cleaner air and cleaner ducts!
Sounds like a good idea to me, so long as the filters aren't too restrictive. Will keep out large junk like cat hair.
We had our ducts cleaned after 30-odd years, and they got quite a lot out, but probably half of it was drywall dust from the original construction.
Ducts don't really need to be cleaned regularly.
Thanks.
I have a stainless steel round brush on a 2 meter cable. Its used for cleaning out the soot in German wood stoves and the heat exchangers they put next to them. Are those bristles similar to what the professionals for cleaning ducts? These are available all over Europe for about 6 euros. They work very well on soot, just be sure you and the brush hit the shower right after you clean up the mess! The soot (lampblack) will really stain fabric and unfinished wood.
Generally the pros use an air hose with an air "brush" on the end.
Check out Rotorbrush.
we've got flex duct, that thing would probably eat it up and spit the residue out of the registers.jose c.
"Though I don't think" added Deep Thought "that you're going to like it."
The commercial equipment is a plastic bristle brush shapped like mine on the end of a vaccum cleaner. Something to remember if you want to DIY.
Mine is just for metal stoves. The stoves are often built into a Ceramic faced shell and they exhaust thru another heat exchanger ( look like the really old cheap air tight stoves I saw in Maine) and then up thru the house. You get the firebox really hot then close if up and the heat seeps off for hours. They really need those wire bristles on mine to scrape the soot out. Its a real messy job but the stoves heat much better when they are clean.
Read the rotobrush web site. They claim it won't harm them.
Absolutely. Good filtration (MERV 7 or better), upstream of the fan, is all that is necessary.
Duct cleaning, in the absence of a significant contaminating event (fire, flood, construction, etc) is up there with snake-oil for well perpetrated scams.
1 more scam vote
35 years in present house, heated with wood furnace for close to 30 of those, then HP (same ducts) still clean, only have ever used the simple fiberglass filters.
