Air Sealing During Gut Renovation of a Single Room
Jared_D | Posted in Energy, Heating & Insulation on September 18, 2023 04:31pm
I’m currently in the middle of a full gut renovation of a single room in our 1904-built home in Wisconsin. The room in question is a former dining room which will become our new kitchen. We (my wife, dog, and myself) are currently living in our home as I take on a renovations one room at a time, with plans to eventually gut rehab most of the first floor and some of the second.
Here’s my question, how do I air-seal the shiplap sheathing from the inside now that the walls are open and the old plaster, lathe, and insulation are removed? Is closed-cell spray foam my only realistic option here? I’d prefer to avoid extensive use of spray foam given its high Global Warming Potential. One alternative that I have looked into is spayable caulking, specifically Knauf’s EcoSeal, which is mentioned by Martin Holiday in an article on GBA, https://www.greenbuildingadvisor.com/article/air-sealing-with-sprayable-caulk . While it seems anyone can buy these materials direct from Knauf, the minimum order size is an entire truck load – I’m assuming that’s a bit more than I’ll need.
The room’s dimension are ~12′ x 17′ with 10′ ceilings. Two of the walls are on the exterior, which totals about 290 square feet of exterior wall space, minus two new casement windows. The existing wall assembly consists of (from the outside in) vinyl siding, 1/4″ of blue foam board, the original clapboard siding (in very rough shape), a disintegrating layer of rosin paper, shiplap board sheathing, 2×4 walls with blown in cellulose, and the original plaster and lathe on the interior.  While I’m not aware of any major problems with water infiltration, the house is a bit drafty – especially around our windows (vinyl inserts in need of replacing).
Eventually, I would like to replace all of the siding and wrap the whole house in 4″ of polyiso and at that point would be able to airseal all of the walls at once from the outside, but that project is likely 5+ years down the line at the rate I’m working. Should I even bother trying to air seal the sheathing from the inside? Would it make more sense to just install rockwool batts and rely on the new drywall as the air barrier?
  1. paulmagnuscalabro | Sep 18, 2023 06:24pm | #1
    Hi Jared,
    It might be worth posing this question over at Green Building Advisor as well (if you haven't already). You'll probably get some spirited feedback.
    This might be a decent case for cut and cobbling your insulation. Doesn't avoid the use of foam (rigid board + canned foam), but it'd probably be cheaper than hiring out spray foam, and would fit the piecemeal nature of the renovation work.
    https://www.greenbuildingadvisor.com/article/cut-and-cobble-insulation
  2. Deleted | Sep 18, 2023 08:13pm | #2
    “[Deleted]”
  3. Jared_D | Sep 19, 2023 07:45pm | #3
    Paul,
    Thanks for the suggestions and link. I have reposted this question over on GBA, https://www.greenbuildingadvisor.com/question/air-sealing-during-gut-renovation-of-a-single-room
    Jared
  4. jacksjaney | Sep 20, 2023 03:41am | #4
    In your 1904-built home renovation in Wisconsin, air-sealing the shiplap sheathing from the inside is a wise step to improve energy efficiency and reduce drafts. While closed-cell spray foam is effective, you can opt for alternatives like rockwool batts combined with meticulous installation to create an air barrier. This approach strikes a balance between immediate needs and long-term sustainability, allowing you to proceed with your renovation plans while enhancing comfort and efficiency. Consulting a local expert for regional insights is advisable.
FHB Podcast Segment: Sometimes Spray Foam Makes Sense, Sometimes It Doesn't
Spray foam is a great invention, but it's not always necessary.
