Air tight recessed lighting??
cmbb | Posted in Energy, Heating & Insulation on June 10, 2002 12:33pm
Do they make a recessed light that is air tight? I put four recessed lights in the living room during remodel and I made them air tight. But would like to purchase a commercial product.
  1. DavidEricson | Jun 10, 2002 05:59am | #1
    I seem to recall that somebody does make an air-tight can light.  Or at least that they claim it's airtight.  I'll get back to youif I find one, but you might check at oikos.com, buildinggreen.com, or http://www.eeba.org.  Good luck, and let me know if you find one that works!
    David
  2. rustythevibeguy | Jun 10, 2002 07:50am | #2
    The Lithonia 'cans' I used in my house (33 of 'em) are "almost" airtight, and they were inexpensive (but with the trim kits, the best looking ones I've ever seen).  All it took to make them airtight was a couple of pieces of metal tape (from an HVAC house) over the armored-cable entry and a 'clip' that was made in the housing to temporarily hold the light socket.  I I just caulked the joint where they penetrated the drywall.  Covered the whole thing with 12" of cellulose.
    1. DavidThomas | Jun 10, 2002 11:58am | #3
      I've got 8 recessed lights in my own ceiling and they must be pretty air tight cause the house tested out at 0.07 air changes/hour  ("tight" is considered to be 0.25 to 0.33.)
      They were name-brand stuff at Home Depot.  Maybe $50 each.  IC-rated and the solid metal on the bottom comes with a gasket so the drywall compress the gasket to the metal.
      David Thomas   Overlooking Cook Inlet in Kenai, Alaska
  3. NPitz | Jun 10, 2002 02:00pm | #4
    Juno makes a recessed light called the Air-loc ready housing. When used with the Air-loc trims or an Air-loc gasket they are supposed to be pretty air tight. I don't know what the actual leakage might be, but they are certainly much tighter than most.
Fast, Accurate Wall Framing
