Airtap heat pump
shawncal | Posted in Energy, Heating & Insulation on April 14, 2008 08:21am
Anybody using these yet?  www.AirGenerate.com
A simple retrofit onto existing water heaters.  For the price ($500) and efficiency, it sounds too good to be true…
Shawn
  1. DickRussell | Apr 14, 2008 10:39pm | #1
    In the summer, if you are in an A/C climate, the unit will cool the air around the heater to get heat for putting into the water heater. So it would be a gain. The electrical input to the unit (about 0.7 kw, if I read the specs correctly) also goes into the water. COP would be about 3.0.
    In heating season, the heat pulled from the air around the heater must be replaced by the heating system, so the overall efficiency is mostly a matter of how the house is heated. Also, you'd have to have air circulation to where the heater is, or that air around the heater is going to be chilled as though by a 4600 BTU/hr A/C unit. I think I got the numbers right.
  2. 1hotwire | Apr 14, 2008 11:37pm | #2
    They changed the name of the website, it used to be http://www.beyondpollution.com . There is a video on finehomebuilding.com, here is a direct link http://www.taunton.com/finehomebuilding/how-to/video/air-tap-water-heater-heating-element.aspx .
    Hope this helps,
    Kenny
Drafting the 2027 IRC
  • The New Old Colonial
