I don’t have any experience using airtight drywall as a vapour retarder as opposed to using a poly VB. I understand the general approach but how do you seal the tops of interior partitions and other openings into attics without poly? Is the detailing very time consuming?
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
Air tight drywall is that ... air tight ... not nec. a vapor retarder approach. You either include poly as part of that approach or install a different vapor retarder (e.g. paint). Many air tight drywall approaches, I think, install the ceiling drywall before the interior partitions go up. You also caulk any exposed edges of drywall ... e.g. the bottom edge near the floor.
I'm not sure I follow you. If you include a poly vb then surely you aren't using an airtight drywall approach.
Putting up the interior partitions after drywall would make plumbing,and electrical rough-in a nightmare. What if they are loadbearing?
I know it is a common strategy. Many posters say they no longer use a poly vb. I'm just wondering how they effectively limit air infiltration into the walls and ceiling.
Not sure about the poly. No reason why it would compromise the air tight aspect of the construction. Putting up the ceiling makes plumbing/wiring access more difficult, but other than that ( :) ) it's 'no big deal' ... you drill up through the top plates to get stuff into the ceiling. Not sure about load bearing walls. It's been a long time since I understood the details of air tight drywall so I'm missing a lot of details here.
Of course, in drilling through the top plate and ceiling rock you create a hole in the air barrier, kind of negating the reason for putting up the rock first.
A strong nation, like a strong person, can afford to be gentle, firm, thoughtful, and restrained. It can afford to extend a helping hand to others. It's a weak nation, like a weak person, that must behave with bluster and boasting and rashness and other signs of insecurity. --Jimmy Carter
Actually no, it doesn't negate it as part of air tight drywall/construction is dealing w/ the air that migrates into interior walls and up into the attic through the cracks in the construction ... e.g. between the drywall and the framing. When you drill through the top plate, you foam/seal the hole, but you still have continuous air barrier across the rest of the framing.
But either way you've got to do extra sealing. I don't know why folks don't just do what I did and paint the tops of the walls with some sort of glop after the wiring and plumbing is in.
Pay your money ... take your choice as I always say. It's like the 1st and 2nd law of thermo. Generally a plus in one aspect is a minus in another. Whatever works.
Foil-backed drywall has been used in place of the VB.
So has VB paint. Not hard to get ... not too special, either.
Yeah, but the foil-backed drywall eliminates the need to wear a tinfoil hat.
I'm not sure that it meets the "airtight " definition, but on recent houses we are
building (energy star certified), we are foaming the top plate/drywall junction. Its not
difficult or too time consuming. Its also important to seal any holes in plates as well
as ceiling mounted electrical boxes, exhaust fans etc.
I've considered having the drywall subs seal the drywall to the top plate with the
newer spray foam adhesive that you can use in place of subfloor adhesive, but
worried about quality control with this method
What I did in our house (1976 vintage) is to paint the tops of the studwalls with roof coating -- the stuff that goes on like thick paint and hardens to rubber. You can pour it on fairly thick and brush it around a bit to seal all the gaps, and you get a good seal quickly.
I'm working on my own house, and I've found that yes, its time-consuming. Its a lot of little nitpicky stuff that seems to go on forever, whether its rainscreen, or air-tight drywall, or just flashing a window properly.
Here's a link to a website where a house is built from the ground up using all these principles, and the guy was very good about taking a lot of pictures and documenting things. The air-tight drywall starts about picture 72.
http://www.imageevent.com/okoboji_images/deloreshouse
Dick
We used airtight drywall approach for many years and I wrote about it with pictures here http://www.chandlerdesignbuild.com/indexFull.php?id=vidraMoody&t=The%20Vidra-Moody%20Residence scroll down towards the bottom and you'll see what I'm talking about.
Bascally you run a strip of Tyvek or poly between the sill seal / termite flashing and the mud sill and then tape it to the exterior house wrap and run another between the top plate and the upper top plate and tape that to the exterior tyvek as well, Then you caulk all the interior and exterior top plate penetrations and when the sheet rock hangars are done hanging the ceilings you run around and staple up little 1" strips of sill seal to the top plate so when they hang their wall drywall it will fit tightly to the top plate rather than the normal drafty crack that you have there.
In this house we stapled up the sill seal strips before the ceiling drywall was hung and just ran around and fixed the places that got damaged when they hung the ceilings. The way we cut the strips is we make a slitting jig with an 18" chunk of 2x6 with a couple of 16D nails tacked ialong the edges and four brand new utility knife blades tapped into the end of it at an angle. You get the sill seal feeding it between the nails along the 2x6 and push it through the blades making four cuts (six strips). Once you have a foot or so you just pull it throughand feed it into a clean trash can as you go and you can make several hundred feet of foam tape very quickly and cheaply. grab a slap tacker and a short ladder and you should be able to seal up a house in a couple of hours.
Michael, how do you deal with piers and a tented crawl?http://www.tvwsolar.com
We'll have a kid
Or maybe we'll rent one
He's got to be straight
We don't want a bent one
He'll drink his baby brew
From a big brass cup
Someday he may be president
If things loosen up
Just6 pull the poly up the pier and wrap it well with Tyvek tape to hold it on with a little great stuff against the concrete to make a seal.------------------
For airtight drywall try the following "BG32" gaskets from RCT. Hammer tack them in place on the sides of the plates and elsewhere before the drywall hangers do their thing.
They have some cool sill and rim joist gaskets and wall plate gaskets, too, and they're not too expensive.
http://www.conservationtechnology.com/building_gaskets.html
Billy
Thanks for all the information, I especially appreciate the links.
