airtight electrical boxes
| Posted in Energy, Heating & Insulation on November 16, 2004 05:26am
From my FHB magazines and the cold climate books I have from Taunton Press I thought that air tight electrical boxes with a place to attach a vapor barrier would be in common use. The suppliers I have available act like I am speaking latin when I describe the idea. What gives? Can somebody either send me the name of a manufacturer or tell me why I shouldn’t use sealed boxes?
signed, a Vermont DIY home owner with fiberglass hanging out.
  1. HammerHarry | Nov 16, 2004 05:45pm | #1
    Around here, (Atlantic Canada), we use those plastic hat-like things, and seal where the wire enters them with sealant.  I suppose because it's a lot cheaper than special boxes.
    1. don3 | Nov 16, 2004 05:51pm | #2
      I would be happy with the hat like surrounds but who makes or sells them?
      1. HammerHarry | Nov 16, 2004 06:49pm | #3
        They're on the shelf in our local big box, in single/double/quad box sizes....
        1. Caleb | Nov 16, 2004 07:24pm | #4
          Even easier than the "hats", around here (Ottawa) every one seems to just cut some of the vapour barrier into appropriate sized squares. These squares are "wrapped" around the electrical boxes when the boxes are installed. The wire is just poked through and sealed, and the "wrap" is sealed to the vapour barrier when installed.
          I tried both this method and the "hats", I found the "hats" slower to work with.
          1. HammerHarry | Nov 16, 2004 07:34pm | #5
            Sure, go with the low-tech solution.  Where's the fun in that?
  2. MartinHolladay | Nov 16, 2004 11:13pm | #6
    Don3,
    Here are several distributors of airtight electrical boxes:
    American Aldes Ventilation Corp.
    4537 Northgate Court
    Sarasota, FL 34234-2124
    800-255-7749
    941-351-3441
    Fax: 941-351-3442
    http://www.americanaldes.com
    Distributor / retailer of Ryeco Enviroseal airtight electrical boxes
    Energy Federation Inc.
    14 Tech Circle
    Natick, MA 01760
    800-876-0660
    508-870-2277
    Fax: 508-870-9933
    http://www.efi.org
    Retailer of energy-saving equipment, including airtight electrical boxes
    LESSCO airtight electrical boxes
    LESSCO Low Energy Systems Supply Company, LLC
    W1330 Happy Hollow Road
    Campbellsport, WI 53010
    920-533-8690
    http://www.lessco-airtight.com
    Manufacturer of Lessco airtight electrical boxes
    Shelter Supply
    151 East Cliff Road, Suite 30
    Burnsville, MN 55337
    800-762-8399 -- press 0
    952-516-3400
    Fax: 952-736-3370
    http://www.sheltersupply.com
    [email protected]
    Shelter Supply sells the NuTek box.
    Good luck.
    Martin Holladay
  3. WayneL5 | Nov 17, 2004 02:00am | #7
    When I built my house in upstate NY, I purchased boxes for the interior of exterior walls and ceilings from a hardware store in Canada.  They had a little flange around the box with a thin gasket.  The drywall sealed against the gasket.  The wiring holes had a little piece of foam rubber to reduce infiltration there.  I don't remember the name of the store, but I think the boxes were fairly commonly available.
    Canada's a good place to get toilets that flush properly, too.
    1. don3 | Nov 17, 2004 02:36am | #8
      thanks HOLLADAYM and every one for your suggestions/info. Now I need to go to Canada to see what a real toilet looks like.
  4. DThompson | Nov 17, 2004 03:20am | #9
    If you use the plastic boxes you might want to seal them to your vapour barrier with a good bead of acoustical sealant around the flange.
    1. NormKerr | Nov 17, 2004 08:23pm | #10
      I remember growing up in a house (built in'67) that had cold air blowing thru the exterior wall outlets and switches and struggling to get each one of them sealed with whatever new-fangled system would come along. That hosue was insulated with fiberglass batts.Now I live in a 100 year old house insulated by blown in dense pack cellulose and have never had any trouble with cold air leaks thru any of the wall penetrations on the exterior walls. A whole world better, and lots less fussing around with sealing details.If you have a choice, I recommend sealing up the whole house, rather than only spending time trying to get each individual outlet.Norm
  5. csnow | Nov 18, 2004 08:07pm | #11
    You can create your own sealed boxes on the cheap by caulking all of the holes in a standard box, and sealing around the face.  Technique is also good for old work.
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
