all purpose compound to ‘blend’ drywall to durock
housenut1 | Posted in Construction Techniques on March 7, 2012 09:59am
Due to a remodel job the back side of a shower niche protrudes into a room I plan to drywall. It’s the smooth face of 1/2 durock. How do I blend this into the new drywall I will be putting up.  I thought of using 5/8 without taping the joint and a 1/8 in skim coat of all purpose.
  1. calvin | Mar 07, 2012 07:52pm | #1
    house-
    If it's a joint that tile will bridge over, I would use the same fibreglass tape that was used with the durock, bedded in Durabond 90 (45 if your not slow).  You can top with regular compound.  Make the wall side look decent-no "perfection" but good required behind the tile.
    1. housenut1 | Mar 07, 2012 11:29pm | #4
      Thanks Calvin for the tip.
      Wayne
  2. DanH | Mar 07, 2012 08:36pm | #2
    You definitely need to tape the joint -- either that or make it a "feature".  Mud without tape will quickly crack at the joint.
    1. housenut1 | Mar 07, 2012 11:31pm | #5
      Dan:
      I had a feeling about the tape, thanks for the tip.
      Wayne
  3. DanH | Mar 07, 2012 08:38pm | #3
    The duplicating machine strikes again!
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
