Aluminum F-channel to concrete
FLA Mike | Posted in Construction Techniques on December 4, 2006 02:41am
Tomorrow I will be installing about 150 feet of aluminum soffit.  Does anyone have a preferred method for installing F-channel on an unfinished concrete wall?
Should I worry about corrosion if I install the factory-finished aluminum directly against the concrete?  I was thinking a strip of felt between the two.
The flange on the F-channel- is there a preferred fastener for concrete?  I was originally thinking of running some 2x as a nailer strip for the channel but couldn’t see it working with the F-channel.
I’ve done some searching, found nothing that suits me, I’m hoping someone here knows what’s best.
How do we dance while our world keeps turning?
How do we sleep while our beds are burning?
  1. FLA Mike | Dec 04, 2006 03:45am | #1
    Does anyone remember which issue had the reader tip about building a jig to cut soffitt with a circular saw?
      bstcrpntr | Dec 04, 2006 04:59am | #2
      I dont remember the issue.
      But I do have a jig for soffit.
      I am no artist but will try to sketch it with the cheap paint program and get it to you.
      I can't draw it, email me for phone number and I will describe it to you.
      Friends help you move.
      Real friends help you move bodies!
      Edited 12/3/2006 9:03 pm by bstcrpntr
    2. blue_eyed_devil | Dec 05, 2006 03:35am | #8
      Mike, for  aluminum soffit products I normally don't open the box and just mark my cuts on the outside of the cardboard. I guess you could say that the box is my jig.
      This "system" works perfectly on aluminum products. It works fairly good on most vinyl products too, but sometimes you'll have some chip out if the blade wanders. I don't use and special blade though...usually whatever is in my saw. If I get an unusual amount of chipping, I put a new Marathon in.
      blue
      1. brownbagg | Dec 05, 2006 04:47am | #9
        dont know about harden concrete but fresh wet concrete and aluminimum will make a chemical reaction. Thats why all concrete tools are magnesiumn
    3. jpeeks | Dec 05, 2006 07:39am | #12
      I cut sofit with a slide miter saw.
      1. FLA Mike | Dec 06, 2006 04:12am | #13
        don't have a slider, but it's on my christmas list
    bstcrpntr | Dec 04, 2006 05:11am | #3
    http://www.rd.com/images/tfhimport/2000/May00_Aluminum_Soffit/20000501_Aluminum_Soffit_page005img002_size2.jpg
    try that
    1. FLA Mike | Dec 04, 2006 06:21am | #5
      that's nice
      something like that will do, thanks a lot for that
        bstcrpntr | Dec 04, 2006 11:52am | #6
        i use 1/4 drive pin anchors in concrete. they have plastic oround the pin, so i don't think they corrode the aluminum.Friends help you move.
        1. FLA Mike | Dec 04, 2006 04:47pm | #7
          is this what you mean?
            bstcrpntr | Dec 05, 2006 05:01am | #10
            That is what I use.   Felt would be a good idea behind "F" if concrete is fresh.Friends help you move.
  3. DanH | Dec 04, 2006 05:23am | #4
    I'd think the choice of fastener would be a problem. Any sort of fastener that's hard enough for the concrete will corrode the aluminum.
    Might be worth half a second considering some sort adhesive mounting. Probably nothing available that's reasonable in terms of adhesion, price, and ease of installation, but worth a thought.
    People never lie so much as before an election, during a war, or after a hunt. --Otto von Bismarck
    Matt | Dec 05, 2006 05:45am | #11
    Aluminum is not supposed to be installed in contact with concrete or other cementous materials.   It will corrode badly.
    1. FLA Mike | Dec 06, 2006 04:30am | #14
      someone else was saying it's just fresh concrete.  Is it which one, or both?
      Would you say stucco and aluminum don't mix?  The stuccoer wants to stucco after the receiving channel is up.  Come to think of it, that's exactly how most that I've seen look like they were done.
      I wound up getting j-channel and put up a 2x2 nailer on the block for that.  The only thing is the backside of the channel is touching the concrete.  But then the stucco is going up on the bottom of the channel anyway.
        bstcrpntr | Dec 06, 2006 04:34am | #15
        If it is stucco, or drivit.
        I put a 2x tapconned to the conctrete about 1/8 shy of stucco face, have them tape the F channel when they stucco.  After they are done put in your soffit and fascia.
        I didn't notice a mention of stucco before, or I would of said thas sooner.
        sorryFriends help you move.
        1. FLA Mike | Dec 06, 2006 05:09am | #16
           --- "I put a 2x tapconned to the conctrete about 1/8 shy of stucco face"
          I'm trying to picture this but can't, what's the stucco face?
          I didn't mention the stucco before, I don't think.  Anyhow there's no telling when this will get stuccoed, kind of a slow project for the homeowners I'm working for.  So my soffit must go up now, or I don't get paid until who knows when.
          Edited 12/5/2006 9:10 pm ET by FLA Mike
