aluminum flashing with pressure treated
| Posted in Construction Techniques on May 13, 2002 05:21am
I understand that using aluminum flashing next to or attached to pressure treated lumber will not be allowed under the new building codes. I am wondering what the problem was. Does that include the next generation of pressure treated lumber. What are the other options can a person use?
  1. JamesDuHamel | May 13, 2002 07:34am | #1
    Try galvanized flashing. I like it better anyway. It is stronger, and holds up better.
    Just a thought...
    James DuHamel
    J & M Home Maintenance Service
    "Southeast Texas"
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
