I am adding a bath fan to a house with aluminum wiring. I have seen the CPSC’s site about the AMP connector and antioxidation grease – which I understand is an expensive technique for a one time job.
I was wondering if there are other safe techniques for connecting copper leads to existing aluminum wiring.
The FHB Podcast crew offers expert advice on choosing the right insulation for the roof of a small, balloon-framed home.
Your best bet is to run new copper wire back to a new circuit breaker at the main box. Make the circuit 20Amp with 12-2 wire so you can bring the entire bathroom up to current code.
I agree rewiring makes a lot of sense. Getting as much of the aluminum branch wiring out of the house is a good idea.
'Ideal' makes a special blue wirenut packed with compound for making AL/AL or AL/CU connections. At about a buck a piece they are not cheap but they are approved for this use and a lot less expensive than rewiring.
just get the right wire nuts and make sure the circuit is rated for the fan.
tight and inside a box ... I'd sleep ok.
It's all the other connections I'd worry about!
Artistry in Carpentry
