An embarrassingly simple problem…
Scott | Posted in General Discussion on September 8, 2007 07:30am
We’ve got a tub with a built-in plug that you pick up and spin 1/4 turn to open and another 1/4 turn to close. The basket beneath is clogged up with hair (I’m married to a Sasquatch. LOL!!) so I need to remove the plug assembly. How the heck do you get it out? I’ve tried CW and CCW spinning with constant upward pressure but it stays put. WTF??
Thanks,
Scott.
Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.â€
  1. restorationday | Sep 08, 2007 08:33am | #1
    Normally the top just spins freely on the pop-up post and there is a stud on the bottom of the post. Put a monkey wrench between the tub and the popup top and turn the post and it should free it right up.
  2. gordsco | Sep 08, 2007 11:13am | #2
    On mine, the pop top knob is threaded into the disc. Unscrew the knob and there is an allen screw inside.
    Gord
  3. highfigh | Sep 08, 2007 04:26pm | #3
    No tweezers?
    McDesign | Sep 08, 2007 04:31pm | #4
    I've got one of the "press on, press off" types, and had to get the hair out Thursday.
    Yeah, just unscrew the top cover, and there's a big brass stud inside that actually threads to the basket, allen or standard screwdriver.
    Maybe I was just lucky
    Forrest - not a plumber
    ladyfire | Sep 08, 2007 04:37pm | #5
    (I'm married to a Sasquatch. LOL!!)
    At least you'll never be cold in the winter months! And she won't steal your razor!
    P.S/ I don't know doodley about the drain. Sorry.
    My brain + his brawn = a perfect team
  6. Scott | Sep 08, 2007 05:56pm | #6
    Ok, thanks all. Your responses got me experimenting... with this one you CLOSE the drain and turn it CCW; out it came.
    Thanks,
    Scott.
    Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
    1. Mark | Sep 08, 2007 06:46pm | #7
      Glad you got it fixed...
      Your sasquatch remark brought back a memory...
      "Goony goo goo"
      Anyone else remember this?" If I were a carpenter"
        Sphere | Sep 08, 2007 09:38pm | #9
        Flying saucer, Dick Van Dyke show.
        oh no, that was Uni Ooops.
        "If you want something you've never had, do something you've never done"
        Edited 9/8/2007 2:38 pm ET by Sphere
    2. rez | Sep 08, 2007 09:20pm | #8
      How do you turn it while in a closed position?
      sobriety is the root cause of dementia.
      1. Scott | Sep 09, 2007 08:05am | #10
        >>>How do you turn it while in a closed position?THAT's exactly why it was counter-intuitive from the outset. The supply valve assembly is by Moen, but I can't remember if the drain was by them too.Anyway, you have to close the valve, gently lift it by a few microns to stop it from binding, and then turn CCW; out it comes. Go figure...Scott.Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
        1. rez | Sep 09, 2007 04:39pm | #11
