Can any one tell me what is the different between 4 and 4.5 angle grinder even both accept the same size
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
I'm not real keen about them, but........ I do know that many 4" angle grinders are metric sized, most 4 1/2" are sae. On the 4" you have to make sure you get wheels with properly sized arbor holes. Too large a hole and you've got an off-center wheel- not a situation you want with 20,000+rpm.
Let's hear it from the more knowledgeable...........
i've had both.. the main difference is the depth of cut you can get.
since we do a lot of masonry.. neither one is especially good
my favorite now is a Metabo 5"
Yes, years ago I bought a 5" because it was on a very good sale; didn't think much about it until I watched someone struggling with a 4.5" that had 1/2 the power. It's that big job that reminds you that you often need the full-sized tool.
Phill Giles<!----><!---->
The Unionville Woodwright<!----><!---->
The 4.0 have a smaller ( about .5") dia arbor,,,,, the 4.5 have a .625" arbor, .625 is a more common size. It is much easier to get wheels and brushes for a 4.5".
I had a couple of Makita 4", and very occasionally I guess I could fit one where I couldn't fit a 4.5"( I was pipe fitting at the time), but for most purposes, the 4.5" is the "go to" small grinder.
I would recomend Metabo. Also, I don't like paddle type switches.
Happy grinding, Harry
Not directly answering your question but.....
I have used a 4" Makita and own a 4.5" DeWalt. The DeWalt vibrates so much more than the Makita it isn't even funny. I don't use my DeWalt all that much, mainly for sharpening and coping, but I wish I had bought the more expensive grinder/had done more research on user impression of vibrations. My DeWalt was the cheapie version, they make some that are more expensive.
Edited 10/4/2007 11:45 am ET by K1500
The DeWalt vibrates ...
have you changed wheels? even the cheapest grinder should spin smoothly with a balanced wheel - the only way I can think of for vibration being inherent is if the spindle is turned off center - in which case it would clearly be a manufacturing defect warrenting a return/refund/exchange - -
"there's enough for everyone"
Yep, I have used different wheels. It is not a deep, earth moving vibration, but rather a high frequency, low amplitude hand numbing kind of vibration. I'll have to try it with no wheel to see if that solves it. It isn't horrendous, but that's primarily because I don't have to use it for long periods of time. The Makita just seemed like it was much smoother.
I love these tools, there seems to be more and easier to find disks for the 4.5. I usually do not like Craftsman Electric Tools, but when it comes to angle grinders, I do prefer the Professional Line--get a kit that says 7amps. The kit is a few accessories but the box is what you want--to keep up with different disks for all kinds of jobs.
The Hitachi i got has a terrible switch which everytime i go to turn it off i have to re educate my self as to where and how.
Angel grinder. That sounds like something less than heavenly to me.
You don't want to grind the wrong angel...that's why you need a right angel grinder. ;o)
The 4" takes 4" wheels, and the 4.5" takes 4.5" wheels.
I only have a 4" Makita. I have abused the heck out of that thing. Coping wood joints, cutting metal, grinding all sorts of masonry products.
Small size/light weight is good for coping. For the other things I would like to get a bigger one. The 5" one Mike Smith recommended sounds good.
As far as I'm concerned, the 4" grinders are a waste ... unless you are working in Japan ... where the size is more commonly used.
It's not just the diameter of the wheel; it's also the spindle threads. The standard for small angle grinders is a 5/8-11 thread. In this pitch, you can easily find brushes and other attachments.
If you want a smaller grinder, consider the attachment for the Rotozip.
