Angle for Crown Moulding when corner is not 90 degrees
johndrew | Posted in Construction Techniques on March 13, 2013 08:59am
I have two corners which are about 1/8 and the other 1/4 off when measured with a square at the 24 inch side.
Both are less than 90 degrees.
My question is..What is the approximate angle should I cut on the miter box for a better fit?
or can you tell me how much the angle  would be off in 24″ with a miter of:
44.5
44
43.5
43
Then I can measure the out of square distance and adjust to the approximate angle.
  1. junkhound | Mar 13, 2013 10:02pm | #1
    Off = 24 * (1-ARCTAN (angle cut))
    1. DanH | Mar 13, 2013 10:06pm | #2
      Yeah, for small angles you don't really need a trig table/calculator -- an inch at 24" = so many degrees, to reasonable accuracy.  But I've had a long day, and figuring out "so many" would make my head hurt.
    2. johndrew | Mar 13, 2013 11:10pm | #5
      Missing something
      I Googled Archtan  and got a calculator. Pluged in 44 degrees and got 88.698.
      Off= 24*(1-88.698) = -2,104.75 ???
      Never was good in Trig..got lost after the teacher said bring two sharp pencils to class.
      1. DanH | Mar 14, 2013 06:52am | #7
        They trusted you with sharp pencils?
        1. johndrew | Mar 14, 2013 09:00am | #8
          Dropped Trig
          That's the reason I dropped Trig. All I had was two sharp crayola's.
        2. johndrew | Mar 14, 2013 09:00am | #9
          Dropped Trig
  2. johndrew | Mar 13, 2013 10:38pm | #3
    Inside corners- Cut test patterns
    They are all inside corners. I tried to cope one but did not come out very well and did not have a good rasp to fine tune it. Looked at Amazon but still did not find a good rasp set.
    I did build an open square  box which would hold the  trim at  the ceiling/wall angle  so I could see the backside after I did the cope to see what needed to be taken off to improve the cut. Looked like it needed a lot of caulk.
    I will take your suggestion and cut test patterns. Hopefully I will find a good video on coping and rasps.
    Any suggestions?
    1. finefinish | Mar 13, 2013 10:58pm | #4
      I bet Youtube has some good tutorials.  Gary Katz probably has videos on this but I know he uses the Collins' coping foo with a  barrel grip jigsaw.  I still like a nice coping saw and a coarse sanding sponge for the fine tuning.
      1. johndrew | Mar 13, 2013 11:13pm | #6
        Coping Blade and Sanding grit
        What coping blade fine or course? and grit of spoung? Gosh Gary Katz  makes it look easy
Old House Air-Sealing Basics
