this one sat on top & in front of an existing marble surround
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
the sides of the marble were flush with the base, so I couldnt wrap the sides all the way back without overhanging the base. So I did this..
*Greg, Looks nice, goes well with the marbel, in your post you said "another mantel" did I miss one?
*Looks great Greg- I'll bet you bent alot of finish nails fastening that trim to the marble.hehe
*Greg:Nice job.
*Armin- It was a while ago, in the "Last Nights Project" thread. It's still there, just a few pages back. thanks by the way.Bob- thanks bud- no bent nails tho-(used a ramset!!)actually, it was pretty much a press-fit. A spooge or two of caulk, a healthy shove, finish caulk, & I was outa there!!Stan:Thank you.
*I thought this was a slow time for y. It looks like you've been pretty busy. As always your work looks great .
*thanks Ron- it is a bit slow. Which translates to not workin 16 hrs/7 daze...
*I especially like the proportions of the beaded cove at top.Looks like they're growing their own firewood close by.
