Another pro story!
frenchy | Posted in General Discussion on May 26, 2006 05:52am
Today at the hardware store I saw the ultimate “expert”  at work.. He was chewing out the clerk for selling him lumpy concrete.
“How do you expect me to do nice work with all these stones in it?”  The poor clerk was beside herself.  “you asked for concrete and that’s what I sold you,” she said..
  “But I need the smooth kind for brick work!”
 “Oh, you need morter I voleentered,” thinking I was doing a favor for a do-it-yourselfer.  He actually wanted his money back for the “lumpy” kind.
  As he left I noticed he was driving a nice new 1 ton duelly  with a sign on the side, advertizing Expert chimney repair.
  1. Damien Stokholm | May 26, 2006 05:58am | #1
    Wow.
    tfarwell | May 26, 2006 06:51am | #2
    You know, that first batch of mud in the morning is always hard to get right...
    zak | May 26, 2006 09:02am | #3
    Wow.  If I had known they sold smooth concrete, I wouldn't have spent all that time sifting mine through window screen before I use it.  Live and learn, eh?
    zak
    "so it goes"
  4. bolts | May 26, 2006 10:16am | #4
    Makes me wonder if he ever ate porridge.
    You can make it fool proof but not idiot proof
  5. DanT | May 26, 2006 11:59am | #5
    Amazing.  Doing a little block repair today if the rain ends.  I better check to see if I  have lumpy or smooth.  DanT
  6. MisterT | May 26, 2006 02:00pm | #6
    Every good mason knows that the stones in concrete mix are spacers.
    you get small stones for tight joints and larger ones for big joints.
    aside to frenchy:
    You notice the article in FHB about building a crosscut sled???
    I think you need to set them straight!!!
    Mr. T.
    The Emperor has NO clothes!!!
    the emporer has no closet...
    the emporer has no clue...
    the emporer needs someone to tie his shoes..
    the emporer doesn't care about polls (they can be fixed)
      Gunner | May 26, 2006 03:38pm | #7
      What's wrong with crosscut sleds?
       GIVE ME AN............. F!
      1. frenchy | May 26, 2006 04:03pm | #9
        Gunner,
         My issue with cross cut sleds is in regards to the wood workers who think the only way to cut across grain is on the table saw with a cross cut sled..  You see them dragging out these big homemade monsters with dubious accuracy and try to cross cut an 8 foot 2x4 (for example).
          Or they have some little piece that really calls for a compound mitre saw and they again drag out that big monster and have at it..
          It's the jig mentality.  If they can dream up a jig they will do evewrything from making cove molding to polish their shoes with their table saw..
          Give me a break!
        1. Shep | May 26, 2006 04:41pm | #10
          I worked for a while with a guy that made jigs for everything- some were quite ingenious.
          But frequently he spent more time making the jig, than it actually took to just do the task.
          I don't mind jigs, but some people can get carried away with the building process, and forget that there's supposed to be a result at the end.
          Gunner | May 26, 2006 04:42pm | #11
            So your issue is with people who overthink the problem or the solution? I can see your point on that.
            I'm gonna make one. It's a lot nicer for repetitive cuts of wide stock. But I'm like you if I can flop it up on the miter saw and whack it then that's what I'm doing.
          1. Sancho | May 26, 2006 06:34pm | #12
            Well for me I use the KISS system. If I can use a existing tool to do a job such as a mitre saw..Ill use it. If I can Ill adapt (make a jig) a tool to do the job. If the jig will take longer to make and cost almost as much in materials to make it, Ill buy a tool to do it
                         View ImageView Image
            Gunner | May 26, 2006 06:40pm | #13
              Any jig I'm likley to use has been already built. I'll see one somewhere and make it up if I think I might need it later. Gives me something to do when I'm bored.
          3. Mooney | May 26, 2006 07:17pm | #15
            "Any jig I'm likley to use has been already built. I'll see one somewhere and make it up if I think I might need it later. Gives me something to do when I'm bored."
            Funny you mention that . For a man like your self that can think of all the things you do  for entertainment , I never figgured you were ever bored . But what do I know ? Struck me as funny .
            Tim
            Gunner | May 26, 2006 07:29pm | #16
              LOL. For some reason I thought the same thing when I posted that. I thought about restating it like this. When I'm looking for something to do to take my mind off of everything else. But then thought "What the heck, nobody will care."
              I didn't figure in the "Mooney Factor." LOL
          5. Piffin | May 29, 2006 06:20pm | #19
            We sure don't want you bored! That makes for a dangerous Tavern visit.
            Gunner | May 29, 2006 07:57pm | #22
            LOL Aint that the truth.
        3. philarenewal | May 26, 2006 08:29pm | #17
          >>"Or they have some little piece that really calls for a compound mitre saw and they again drag out that big monster and have at it..
          The one thing I actually do use either the mitre gauge or crosscut sled on the table saw for is the little wee pieces.  Want to be able to count to ten without taking off my shoes.
          If my imagination says fingers/hand whapped into the blade if there's an uh oh on the SCMS, it goes to the table saw/sled.
          Actually had a close call on an old Makita slider that developed a bad trigger switch.  Cutting hardwood shims for a tread/riser install.  When the blade lost power during the cut, you can probably imagine how much force is involved when the blade grabs the wood.  Only reason I still have all ten is my hand got flipped into the side of the blade instead of the teeth.  Happens in a tenth of the blink of an eye.  Like a firecracker going off.
          "Let's get crack-a-lackin"  --- Adam Carolla
          1. frenchy | May 29, 2006 04:58pm | #18
            philarenewal,
              Tablesaws account for more lost fingers than almost anything (except radial arm saws)
              A little 2 inch by 1/4 inch thick by about three inch long piece of wood came flying off mine and broke my arm in two places.  My fault really.  I had been making dado cuts and had removed the guards.    I see way too many table saws used with out the guards in place.
              Can't use a sled with a guard!
            BillHartmann | May 29, 2006 06:22pm | #20
            "Can't use a sled with a guard! "Wrong again.Depends on the quard.However, I don't used the guard on mine. But when I do use the cross cut sled it performs the function of a guard.
  7. tmaxxx | May 26, 2006 03:45pm | #8
    perhaps she did sell him the correct stuff but a few lumps fom his head spilled out and landed in the crete.
    Tmaxxx
    Urban Workshop Ltd
    Vancouver B.C.
    cheers.  Ill buy.
  8. Shacko | May 26, 2006 06:47pm | #14
    AND THEY TALK ABOUT THE HISPANICS NOT KNOWING THE LANGUAGE!!
  9. rez | May 29, 2006 07:09pm | #21
    hoowee is Notchman going to be mad at you fer telling on him!
    be afraid
    be very afraid
    half of good living is staying out of bad situations
Fast, Accurate Wall Framing
