Another question: step footing or not?
Consider that if you don't step your footing, your 2' depth at the downhill side translates to over 10' depth at the uphill side. i don't think you want to mess with footings that deep.
Thanks for the headsup.
Is the difficulty you mention related to digging the rear footing to a 10' depth? (I know I will hit rock, and possibly bedrock)
OR
Is the problem some sort of pressure/movement issue on the foundation because of the foundation's depth?
Just curious. I am definately a take the easy way out (but safe!) kind of guy.
Thanks!
