I have some 1940 era Manco 36 inch long bolt cutters. To “sharpen” the cutter jaws (one or two rough spots) do I just grind them with an angle grinder or are they heat treated in some way?
Edited 12/20/2008 10:47 pm ET by edwardh1
If you feel you can without annealing the hardness, if you ain't certain, send to a saw shop .
I'd break em down and use a fixed bench grinder and quench 2x as often as I think I need to. Follow the orig. bevel angle.
Thanks I can do that but know little of quenching details -do you quench only if it gets red during gringing? and what quench in- oil or water?
If you get it red or blue or yellow, it's too late.
I quench in water, just grind a smidge, dip, grind, dip..or use a fancy water wheel slow grinder.
If it gets RED and you dip, you actually make it harder, and brittle, don't dip and it's annealed ( too soft to cut).
For something as rugged as a bolt cutter, a handheld is what I'd grab at first,a nd just kiss it lightly a few times, no steady stream of sparks.Spheramid Enterprises Architectural Woodworks
I was able to order new jaws for the ones I got from grandad (48") from McMaster-Carr.
I used the old ones for the jaws of a giant welded-metal stag beetle 'artwork"!
