hi there Does anyone know of a way to identify an antique sprayer made in Worcester MA around 1927 by the SDG Ideal Spray Co . ?
Keeping HVAC systems within the conditioned enclosure can be tough without a basement; one option is to use plenum trusses for the roof, which offer a space for equipment and ductwork.
are you looking for one? - - look at the tags and serial numbers....what size machine is it? a pump up or single cylinder - carry around or wheeled? - I've got a few resources on orchard equipment from that era - will check if you give me details...
I am in receipt of an antique sprayer made in Worcester MA in 1827 by the SDG Ideal Spray Co. I am trying to identify this tool. Did you ever get an answer on what this is used for? I am attaching 2 photos.
Thank you for your help.
That's a bit bizarre -- looks more like a sausage stuffer than a sprayer.
Presumably it's missing a piston of some sort, that would engage with the cogs on the arms.
missing the piston........
and I would presume a tank and hose.
Boy, that would be a cumbersom operation.
I agree it's not a sprayer - and I agree the piston is missing - looks to be for forcing relatively small amounts of something, possibly lubricant, into something thru the fitting at the end of the tube - but if that were the case, I'd expect the tube to get buggered up -
dunno - interesting - nice clean up job, but that's removed clues as to its function -
what's the end of the tube look like?
Well the lettering on the main body is clear enough -- it's from a sprayer company. It could be a duster perhaps -- load powder into the chamber, insert the piston, and pump like a bellows to blow the powder out. Or could be some sort of a grease gun.
A close examination of the nozzle end might give more clues.
Geez, looks like something Torquemada might have a use for.
It looks like something my 3rd grade teacher used.
I believe that tool was used to cure unfaithful husbands and other various and sundry cads.
Were they really doing that kind of press work in 1827?
I wonder if it's actually Victorian or later on an older patent or design.
Do you have a patent date?
Is the 1827 part of a patent date? What does the business end of this thing look like?
It says right on it -- "PAT'D
It says right on it -- "PAT'D JAN 82".
SDG Ideal spray tool
Did you ever find out what this item is? I just came across one.
Sausage Stuffer...
... might be spot on!
Check out the small groove behind the knurled front band on the "output" end of the pressure tube. There's a small ring which could be meant to receive the string that'd secure a sausage casing ("guts" suitably processed) to that fitting, the better to hold in place the material being expressed by means of the lever-actuated (missing) piston.
