So this round metal disk is in our wood floor in the dining room. It is close to be centered in the room, but not quite. The floor finishers said they never saw anything like it.
So, any ideas?
So, any ideas?
It's a cleat, to secure a pole in the middle of the floor. It has a threaded hole in the middle, right? Maybe for indoor badmitton net or a GoGo dancing pole?
OK, I think I like the Go-Go dancing pole idea best...
go-go dancers from back then
Seems like flappers would have been more likely. Now I just have to find the bathtub gin stash. But I guess that explains the huge tub we have.
what appears to be indentations in the surface would accept a spanner wrench, which may indicate it being a threaded plug. Maybe to accept one of those cool patio umbrellas? or a tetherball pole?
dunno...
gb
Unscrew it and find out.
You gotta use a pin wrench. Basically a metal bar with two pins through it in the right place to stick in two of those holes.
It looks like an old screw on cover for a gas or steam valve.
Politics: The blind insulting the blind.
I've got an adjustable pin wrench. Bicycle bottom brackets used to require them. Not sure now with the huge technology changes in bicycles.I've got to check for the threading. Calling for the help makes sense, but I was kinda hoping it was THE button. You know the one people talk about? "The president has his hand on the button" or "she knows how to push his buttons".
There was gas lighting here. I've kinda wondered about a gas candleabra thing for the table.Or a big lazy susan, like they have at chinese restaurants.
Ashtray foot.
There is no cure for stupid. R. White.
It's what is left of a footswitch, usually hooked up to a ringer that alerts a maid or butler.
I think you're right, it's the remnants of an old footswitch used to call the maid or butler. I have something similar in my house.
BTW, do you own an MV Agusta bike as your screen name suggests?
Nope, I wish I did, the only bike I have now is a '77 R100RS that is sorta dead-in-the-water at the moment. I'm looking at my floor-switch right now and it looks like they didn't bother pulling the brass cover off before the last floor sanding. The antique store down the hill has one of the original bells from this house, it had a lableled ringer for each room. She wants $275 for it, I don't think I need it that much.
That's it. I have a brass one in the middle of my dining room floor....that's not a mistake, it's rustic
Really? Interesting. Tell me more of what you know.
That's about it, most of the houses around here pre-WWI had them, the town was more of a white-collar bedroom borough then. Other rooms had a wooden handle that hung from the ceiling or wall with a momentary pushbutton switch on the end. All of the wiring normally led down to a butler's pantry, to a box called an annunciator, which had latching relays inside.
Interesting. I have never ran into that type of thing.
Most of them did not have latching relays, but probably some did.What they have is a "flag" that was lead in place with a latch. And one end of the latch was controlled by a solienod. When the solienod was powered it pulled alway one part of the latch allowing the flag to drop.Here are a couple of examples.http://mysite.verizon.net/dalderdi/phones/annunc.htmhttp://www.residentialarchitect.com/industry-news.asp?sectionID=152&articleID=313411&artnum=2http://www.rrmtf.org/cantigny/annunciator_in_butlers_pantry.htmand here is a call button that was on a cord.
I haven't seen the guts of one in awhile, but I'm pretty sure that you are correct about the solenoid vs. relay thing. If the store down the street is open today after work I'll get a picture of the one they have.
Don't take it out. It is the schrader valve for the planet.
lol!
thats funny. i cant stop gigglin.Tmaxxx
Urban Workshop Ltd
Vancouver B.C.
cheers. Ill buy.
It's the center of the tension ring that's holding your house together. If you take it out, the whole floor system will fall into the basement.
Bob
It's the Primary USGS Survey Marker for Ohio - ya better not move it!
Unscrew it, take another picture, post it, and we'll all know. Personally, I think it's an outlet for a light on the diningroom table, or a gas valve for the same before they had electric.
Well, I'm out of town for a week, but I'll see if anything unscrews when I get back. The bottom side is covered up by air ducts, so I can't see it there. I've never thought about it unscrewing though.
alright Bryan, what is it?A great place for Information, Comraderie, and a sucker punch.
Quittin' Time
I've been out of town, but I'll try and check tonight if I can unscrew it. But I think the underside is hidden behind ductwork, so if it doesn't unscrew, I'll still know only what you know.
Well, I tried to un-screw it with my adjustable pin wrench, and I couldn't budge it. Plus the under side is hidden by duct work.FWIW, the two outer most plus the one hole next to one of the outer most are just depressions, making me think they might be for alignment. The other holes go down to something.I want to re-do my air returns (line the joist bays) at some point, so I might have the ducts down. Then at least I'll be able to see the bottom, unless it doesn't go through the sub-floor.As for the phone jack, the location seems wrong. The middle of the dining room? But some sort of switch to call the butler or cook, that I can buy.
I don't think it unscrews with a pin wrench. I think you just remove the wood screws holding it down.
Shoot man, the answer at dinner is whatever you wish to tell the guests. We'll back you up.A great place for Information, Comraderie, and a sucker punch.
Quittin' Time
Actually at dinner it is normally hidden and I don't even think about it. It's under the table then.Which gives me a new idea. Maybe in addition to the boarding house, the owner decided to pick up some extra $ doing seances. It was used for communicating with the dead.
Perhaps to turn on the smoke.A great place for Information, Comraderie, and a sucker punch.
Quittin' Time
"It was used for communicating with the dead."maybe you should talk to the dead about this . . . nobody here seems to know <g>is there an internet connection to the underworld?
Yeah, 666-Base-T.
I'm thinking four pin plug in socket for telephone from another era.
I honestly don't know, but I have a shadow of a memory bumping around in this head that I have held one in my hand, but I can't remember where or why.
Probably Bell's prototype....Andy
"Never try to teach a pig to sing. It wastes your time and annoys the pig." Robert A. Heinlein
"Get off your dead #### and on your dying feet." Mom
"Probably Bell's prototype...."Right - now I remember - it was just before he fired me for having better ideas than he did.;)
You unscrew that thing, I'm thinkin' you just might find Mr. Hoffa.
Maybe Pandora's navel
Remnember the joke about the guy w/ the big strerling silver screw in his navel? Well, you take that thing out & you know what will fall off your house? Don't ask - the blue noses will censor it.DonDon Reinhard
The Glass Masterworks
"If it scratches, I etch it!"
Miniature golf cup, unscrew it and play a game.
I still like the idea of a Go-Go dancers pole
gb
"I still like the idea of a Go-Go dancers pole "
that's just a good idea in general.
all the time.
anywhere ...
Jeff Buck Construction
Artistry In Carpentry
Pittsburgh Pa
I'm with ya, brother...
gb
It looks the the detonator of a five hundred pound bomb. Hit it real hard with a two pound hammer and see if it goes off! :-)
Constructing in metric...
every inch of the way.
It looks like I can see a bit of wood through the center hole, making it unlikely that this is any sort of cap over a valve or some such. More likely it's a base or cleat for something to be attached.
My first thought was a pole base of some sort, but more likely something like the butler call switch that was suggested. These would be secured to the dining room floor, under the dining table, where they could be reached by the toe of the master/mistress of the house.
If it is indeed the base of an old switch there will likely be some old bell wire (or at least a hole where the wire used to be) coming up through the floor under the plate.
Bell for the maid. Our apt (prewar West side Manhattan building) had one - so did my inlaws', in an even nicer building -
