I’ve heard from a few bulders and friends that Hydro Air systems are great a compliemt if you are putting radiant heat in the house, which I plan to do.. Do these systems make sense..
Any pros/cons woould be appreciated.
In this FHB Podcast segment, the crew offers expert advice on insulating an old home and finding the right contractor to do the job.
Absolutely, this makes sense. An air handler with a built-in txv coil (for cooling) and a hot water coil to provide warmed ventilation while the RFH warms the house, is a very good compliment to a hydronic heating system.
Along with the hydronic AHU, an indirect water heater is another excellent compliment to a boiler based system. The condensing/moduclating boilers available today will provide comfortable winter heat and domestic hot water at efficiencies that no other (or very few) residential systems can match.
I've liked the design, and the company has been fine to talk to, but even though I've recommended it to perhaps a half-dozen design clients, each has eventually gone another route be/c of cost of the system. Wish there was one where the cost seemed to better match people's expectations.
Just finished installing ours last week. I added the heating coil to our unico system to back up the rfh. I am now waiting for sub zero temps to see if it does what I intended it to do.
HydroAir is different from Unico. I have Unico...after the first year, disconnected the heat element and used the supply line to add flow to the RFH...we have so much volume that we never noticed the heat it provided. Should be better if ceilings not too high.
I have some high ceilings in a room with lots of glass so I installed the hydronic coil in the unico system. I am hoping that takes the chill out of that room, and with some air convection, the ice on some of the windows may not form during sub zero periods.
I had considered the unico as much.. are the costs similar? thanks for the other comments in here as well..
I have not compared costs. I purchased ours direct from the distributor, if I recall correctly the material costs 4 years ago were betweem 4 & 6 k. That included air handler, outside unit and ducting to cocer 2,900 s.f. house. The ducting cost as much as the mechanical equipment.
