When I bring up this site, I cannot even get to the photo gallery. I tried switching to “all” from “unread” and still no photo gallery. Has everyone given up? I want to post some pics.
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
Gene, click on 'post new', located above the 'show discussions' option box (where you selected 'all' from 'unread')- on the sceen it brings up there is a box to 'select a folder' and you should select 'photo gallery' and proceed - if you want to view the photo gallery contents, scroll down to the 'photo gallery' banner and click on it and it will display the contents of the gallery - hope this helps, DOUD
http://forums.taunton.com/n/mb/list.asp?webtag=tp-breaktime&ctx=16384&cacheTag=x40-1Excellence is its own reward!
