Anybody still wipe lead?
junkhound | Posted in General Discussion on December 23, 2009 09:08am
Anybody still know how? Tried it a couple of times 50 years ago, made a mess but didnt burn myself too badly.
  1. BillBrennen | Dec 24, 2009 01:33am | #1
    Sounds like one for the Old Plumbers' Home. I know a plumber in his 70's who worked in Michigan for many years and I am sure he learned to wipe lead as an apprentice. I'll have to ask him next time we talk.
    1. maverick | Dec 24, 2009 05:51pm | #4
      Geez, I still have my ladle and half a box of oakum that I have'nt used in 25 years. ya never know...
      1. jc21 | Dec 24, 2009 08:23pm | #5
        How would you rate a poured lead oakum joint vs a no-hub connection? Longevity, etc
  2. rdesigns | Dec 24, 2009 09:42am | #2
    No, but I have a good supply of plumber's candles if you really want to go backwards.
    I also have the bending springs that were inserted inside a length of lead pipe so you could bend your own 90's (or 89's, or 92's--whatever you needed.)
    My old, old plumber's how-to book has a page of 13 rules for safe handling of lead. My favorites:
    #3--"After having been in the dust or the fumes, spit a few moments thereafter."
    #12--"Do not keep your mouth open when breathng; breathe through your nose."
    #9--"Do not allow yourself to become constipated."
  3. Shacko | Dec 24, 2009 05:16pm | #3
    To wipe lead was basically a separate skill, you
    would be pressed to find someone that can pour a
    lead joint nowdays; most people don't know what you
    are talking about.
    1. junkhound | Dec 30, 2009 08:53am | #7
      Yep, most folks probably have never even seen a wiped joint. Still have a few pieces of asbestos cloth for wiping, but no 1-1/2 lead pipe left in the 'inventory' even.
      As to the other post about longevitiy of oakum joints - I have seen CI pipe fail due to rust through from the inside out prior to the lead oakum seal failing.
      Have personnaly seen wiped lead joints in Pompey that still appear functional after 2000 years.
      1. rdesigns | Dec 30, 2009 09:39am | #9
        Lead is great for longevity, and so are its alloys that go into solder--tin, antimony.
        But now, instead of being afflicted with lead poisoning, everybody has come down with lead-phobia.
  4. BURT | Dec 29, 2009 11:14pm | #6
    When I remodeled by house in Long Beach in 1977, I needed to connect my new ABS drain from the new bath/laundry to the old existing cast iron drain. At the time I was getting help from the old timer at the local plumbing supply store counter. He sold me oakum and "lead wool" to use to make the connection and explained how to do it. Worked like a charm. I tamped the oakum into the cast iron bell and followed with lots of lead wool carefully tamped in place with an offset lead caulking tool which for some strange reason I already owned. I think the idea is that lead is soft enough that the wool could be hammer compressed enough to be solid and leakproof.
    I was glad to not fool with hot lead in the crawl space under the house. As I understand it, to make a good lead joint, the lead has to be just hot enough to flow and just cold enough to set up in the joint almost immediately on contact. I can see that level of expertise needing lots of experience to develop. I think lead joints were usually "finished" with the above mentioned caulking tool. My guess is that cooling lead could contract and get a little loose in the joint.
    plumber_bob | Dec 30, 2009 09:26am | #8
    I took my Journeyman test 2 years ago, and they had switched from pouring lead joints as part of the test, to figuring your cast iron pipe lengths, and hooking them up with mission bands. Your work must fit into a 'Jig', perfectly and they check for proper torque.
    Actually, I haven't even heard of anyone pouring a joint, they just cut out the area, and replaced it, using no-hub couplers, and PVC.
    We still install cast iron sometimes, mostly 4", and underground, but we use a rubber hub and some kinda grease. I don't know how it holds up in the long run, but it looks good, and does seem to seal well.
    1. Shacko | Dec 30, 2009 01:07pm | #10
      plumber_bob: A lot of times it is more economical and
      faster to pour a lead joint if you are set up to do
      so.
      The lube you are talking about is slip-seal lube; you
      also use a adhesive-lube in certain situations. That
      type of hook-up has been around since at least the
      early 60s, I've never heard anything negative about
      it.
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
