anyone done 2×4 on-edge decking?
JCG123 | Posted in General Discussion on March 10, 2008 09:17am
I’m replacing deck boards.  Joists are 16 inch on center.  I’m wondering if P.T. 2x4s on-edge would stand up better to sun & water?  What do you use for permanent spacers?  (I’m thinking something like clear plastic might be good – certainly want something waterproof.)
Thanks!
  1. FastEddie | Mar 10, 2008 09:35pm | #1
    Why would you want to more than double your material cost, and still end up with syp boards?
    1. JCG123 | Mar 10, 2008 09:43pm | #4
      Maybe it lasts longer with less splintering, cracking, rotting?
      Still cheaper than composite and or plastic?
      Looks better than plastic.
      Would be strong enough for diagonal installation.
      1. CAGIV | Mar 11, 2008 02:50am | #6
        THink of installation time, you need to install 4 boards to 1.  I doubt it would be any cheaper in the end and you'd still end up with an inferior product IMO.
      2. florida | Mar 11, 2008 03:21am | #7
        Here's a 2" X 8" PT dock my brother built 10 years ago. It's on the SC coast and still looks great. I told him not to do it but he went ahead and did it anyway. I think the trick is that it's screwed on from the bottom up so there are no fastener holes to let water in.
  2. MikeHennessy | Mar 10, 2008 09:41pm | #2
    I've seen it done, but my impression is it's worse. On the ones I've seen, the wood tends to twist/warp more, so spacing becomes more of an issue. Also, I don't think it dries out as well, so you get even more moisture issues that you ordinarily would have. You also have the problem created by the instability of standing a 2X4 on it's thin edge -- so it "wobbles". Don't know how they are fastened, but it's likely a PITA to do.
    Mike Hennessy
    Pittsburgh, PA
  3. paul42 | Mar 10, 2008 09:43pm | #3
    I did one like that about 27 years ago.  I ended up with a very sturdy deck, but a very rough surface - any bow at all to the board really showed up.
    Highly not recommended.
  4. reinvent | Mar 10, 2008 11:48pm | #5
    If you want a deck that will last go with Ipe. It has been on the Atlantic boardwalk for 40+ years exposed to the ocean and still going strong.
    http://www.ipedepot.com/picelist01.htm?gclid=CPCp6MO0g5ICFQV4HgodOG-a2A
    http://www.advantagelumber.com/ipedecking.htm
  5. Henley | Mar 12, 2008 02:16am | #8
    I was laying stone on a job where the Carps
    were doing that.
    They spaced it with squares of P.T. plywood.
    Looks cool but man what a lot of work and wood!
  6. RobWes | Mar 12, 2008 02:51am | #9
    I had a WRC deck done with 2X3's on the flat that was solid as a rock. Only the frame was PT.
    Personally I hate PT and avoid it at all costs. You could not give me a 5/4 board of that ####.
