anyone ever order from ovis
alwaysoverbudget | Posted in General Discussion on April 22, 2009 06:06am
need some 3/4 overlay european hinge  [because i screwed up drilling the cup holes!],found some at a good price at ovis.never heard of them before,but went ahead and ordered some hinges and slides.
any reviews?
YOU ONLY NEED TWO TOOLS IN LIFE – WD-40 AND DUCT TAPE. IF IT DOESN’T
MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN’T MOVE AND DOES, USE THE
DUCT TAPE.
    xxPaulCPxx | Apr 23, 2009 10:19am | #1
    Apparently not!
    Oh sorry, did I ....  BUMP?
    Tu stultus es
    Also a CRX fanatic!
    Look, just send me to my drawer.  This whole talking-to-you thing is like double punishment.
  2. migraine | Apr 24, 2009 07:36am | #2
    how did you screw up the hinge hole boring? too far from the edge? wrong diameter?
    35mm or 40mm?
    been there done that.
    Bondo works great. patch and rebore
    1. alwaysoverbudget | Apr 24, 2009 03:07pm | #3
      i have a boughten jig that i used to set up the setback of the hole. well the hinges i used came with a template that showed the hinges needed to set back about a 1/8 farther.
      no problem on my single doors,there just off center 1/8. but on double doors with no stile they hit! so i could trim a little off each door[they are all finished now] or find some 3/4 offset hinges instead of 5/8 to move them outward.
      i was finding 3/4 hinges at 5.00 per hinge,ovis had them for 1.20 so i ordered some from them,they say there shipped and heading this way.
      just a screw up,but at least the doors are still good..... larryYOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'TMOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THEDUCT TAPE.
    Gene_Davis | Apr 24, 2009 03:15pm | #4
    Their pricing is good, particularly so on drawer accessories in the Rev-A-Shelf line.
    Like many distributors nowadays, their inventories are lower, and often you have to wait for something because they need to order it.
    "A stripe is just as real as a dadgummed flower."
    Gene Davis        1920-1985
Mortar for Old Masonry
