Anyone heard of a glue like this??
jcornell | Posted in General Discussion on June 16, 2006 11:52am
Getting ready to lay carpet in the basement of the home and remembered how much I hate fighting with tac strip on concrete. Seems to me that every other nail busts out. A while back a friend told me of a glue similar to a construction adhesive that he had used (he is a professional installer). Put down a bead, spritz with water, press into the glue and sets up solid in short amount of time. No longer have a contact # for this guy so hoping someone knows what he was describing.
  1. BillBrennen | Jun 17, 2006 12:26am | #1
    What you describe sounds like a fast-curing polyurethane adhesive. The water reacts with the glue to cure it.
    I've never heard of this application, but it sounds entirely plausible.
    Bill
  2. BillBrennen | Jun 17, 2006 12:32am | #2
    J-
    Just reread your post. Your friend may have been using PL Premium construction adhesive. It is polyurethane based, and sticks very well indeed. Spritz the carpet backing, then smoosh down into the glue, flattening the bead. I'll guess you'd still need half an hour to get any strength out of it.
    Pl Premium is sold at the Home Depot, as well as at most lumber yards. It came out around 1990, and is a great product. I've used it since 1991.
    Bill
      BillHartmann | Jun 17, 2006 01:49am | #3
      But PL preminum is not that fast.
        DDay | Jun 17, 2006 04:32am | #4
        I know with Gorilla glue, you need to have it clamped on fastened because of the expansion.  I would imagine the PL is the same.
  3. andybuildz | Jun 17, 2006 08:22am | #5
    I always use a lump hammer when installing tack strips on concrete with no problem at all. try it..it might help.
    If Blodgett says, Tipi tipi tipi it must be so!
    TipiFest 06~~> Send me your email addy for a Paypal invoice to the greatest show on earth~~>[email protected]
    1. butch | Jun 18, 2006 04:56pm | #7
      Okay I'll ask, what is a "lump hammer"?sledge hammer?
      1. andybuildz | Jun 18, 2006 06:04pm | #8
        Mini sledge hammer,,,If Blodgett says, Tipi tipi tipi it must be so!
    2. jcornell | Jun 20, 2006 05:51pm | #9
      What is a lump hammer. I usually just use my framer.
  4. Jason99 | Jun 17, 2006 08:31am | #6
    The Product is called Urathene 941 From Chemrex.  You can do the same thing with PL polyurathane.  The trick is to wet the strip.  If you don't it will take 24 hours to stretch.  If you spray it you can stretch in 2 to 4 hours.  Cut your pieces in 10 inch strips to keep them from bowing and screwing up your placement.
    Jason
    1. jcornell | Jun 20, 2006 05:53pm | #10
      If i am reading right, put down a bead then wet strip, not glue, befor pressing into glue, correct.
      1. Jason99 | Jun 21, 2006 06:59am | #11
        I like to cut a bunch of pieces of strip.  Then throw them in a bucket of water.  Then I will run a bead down the wall 15 to 20 feet.  Then place the moistened strips on the glue and wiggle them around a bit to spread the glue.  Then repeat until your floor is covered.  I prefer to glue architectural strip (2 inches wide).
        I have only ever glued the stuff down in situations where there is hydronic infloor heating issues.  Nailing is faster but don't buy the crappy strip from Home Depot.  Go to a real floorcovering wholesaler and buy strip with 5/8ths nails.  If you ask for concrete tack strip they will sell you 11/16 prenails.  They are thinner and longer.  That is the reason people have so much trouble nailing concrete strip.  It's up to you but I can hand nail 2 to 3 times faster than I can deal with glueing.
        1. jcornell | Jun 21, 2006 04:30pm | #12
          thanks for the responses, will let you know how it turns out
          1. BryanSayer | Jun 21, 2006 05:57pm | #13
            You should also check about removing the strips, whatever way you put them down. Concrete does vary in how hard it is, so maybe try the concrete nail strips, and if has too many nails not grabbing, switch to glue.Does anyone ever put the strips down with a powder accuated nailer?
          2. Jason99 | Jun 21, 2006 10:56pm | #14
            It's way too expensive to use a powder actuated nailer.  There are pnuematic t-nailers out there for installing concrete strip.  However in my experience they only hold 50% of the time and really crater up your concrete making it harder to hand nail.  I've had a duofast T-nailer and a spotnails t-nailer.  I was not really happy with either.
            Just for comparison sake It takes about an hour to hand nail 400 linear feet of concrete strip on a fresh slab ( less than a year old)
            It takes me two or three hours to glue.
            They make special drill bits @ flooring supply houses that are just 1 1/2 inch pieces of square carbide.  It is not at all like a normal concrete drill bit.  You drill your holes with a hammer drill then drop in special aluminum nails.  The nails and bits are made by Halex.  This can take all day and use 5 or six bits.
            I have a Semi auto hilti but the cost on the loads and nails would be about $40 per hundred linear feet of floor.  I can also hand nail faster than I can advance a cartrige and drop the nail.
            Carpet installation sucks sub it out.  :-)
Mortar for Old Masonry
