have anybody here ever repaired an oven. I have a 110 oven that wont heat up, but I,m geting 120 volts at the heating coil, and the heating coil is showing continune, no breaks in coil
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
you sure it's a 110V oven???
go reset the breaker...
is the breaker one or two ploe???
WOW!!! What a Ride!
Toaster oven?
“The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing.” —Albert Einstein
didn't think of that...
very well could be...
Plug it in.
Click away from here
Do not click here what ever ya do
Bad things happen to those who click themselves
Basically it's either a bad contact, broken wire, broken element, or broken control. Generally figuring out which isn't difficult. What's difficult is making the repair if it involves wiring. You need high temp wire and connections that can stand the heat.
Check the neutral wire, could be real easy like the wire at the molded is broke.
