applying orange peel texture
roykotzur | Posted in General Discussion on March 14, 2005 04:03am
How much air presure is normally used when applying orange peel texture with an air texture hopper gun and wall and ceiling mix?
    Canabuild | Mar 14, 2005 05:32am | #1
    The best is to experiment on some scrap board before you begin. I use a marshmellowtown hopper and run it at about 40 psi for a nice even texture. BTW- experimenting will also let you find the right setting for the gun, I usually use the smaller increments for the look i like.
    Quality Craftmenship at prices nobody can afford!
  2. TomT226 | Mar 14, 2005 01:58pm | #2
    With my old hoppergun I use about 20 psi, 3/16" tip, and 1 qt of water per box of mud.  Make sure your walls are primed.  Texture will set up quicker on primed rock than unprimed.  Shoot a test on the walls you're going to texture.  If you don't like it, use your 12" knife to scrape it off, and adjust your coverage speed/distance/air pressure.  The more pressure, the finer the splatter and the less strike-down you have to do.
  3. butch | Mar 15, 2005 01:25pm | #3
    What Tom said.....
    But the important step here is the priming before texturing
    1. FastEddie1 | Mar 15, 2005 03:51pm | #4
      Thinner mix takes less pressure to spray, and leaves a different spatter.  Yoiu need to be consistent in how you mix the batches so you don't have to adjust the gun and compressor from room to room.
  4. Mooney | Mar 15, 2005 05:41pm | #5
    Depends on what you want to call orange peel.
    There are different needle sizes and then the dial size. The amount of paint ot water you add also makes a difference . I like to mix vinyl primer with it and paint the wall with the spray and then come back over it with the desired texture. I paint the wall with a small orfice at 100 lbs pressure . The load up on orange peel is done at about 30 lbs, but pressures dont mean a lot if your material and equipment are different.
    Tim Mooney
Mortar for Old Masonry
