Architectural Shingle ridge detail?
Chargerny | Posted in Construction Techniques on May 1, 2006 10:01am
I feel stupid asking this question, but I can’t seem to figure this out myself.  I just put a new IKO architectural shingle roof on my garage and I can’t figure out what the ridge detail should be.  If it were 3-tab I’d know what to do, but when I look at other archectural shingle roofs in the neighborhood I’m pretty sure they didn’t just cut the shingle in thirds and bend it over the ridge as you’d with a tab.  I’m equally sure that they didn’t cut the shingle in half the long way and use the upper (normally hidden) half in thirds because the color is wrong.
Is there a special ridge cap shingle I should have bought along with the regular shingles?  Am I wrong about what others have done?
Thanks in advance for the answers.
    Gene_Davis | May 01, 2006 10:09pm | #1
    Yes, you need to use the Iko hip-and-ridge shingle components for your ridge.  The archicturals, like the Chateau, won't do it.
    Your supplier has them in stock, most likely.
    McDesign | May 01, 2006 11:05pm | #2
    I just get 3-tab in the same color, and cut them normally (into thirds; taper the tops) - maybe halve the exposure or vary it 0-4 inches to "lumpify" or break up the ridge line somewhat.  Also cut the 3-tabs to use for starters - it's cheaper.
      zak | May 01, 2006 11:28pm | #4
      I agree with you about the ridges/hips, done with 3-tab.  I just don't like the look of the high profile hips I see.zak
      "so it goes"
  3. VinceCarbone | May 01, 2006 11:13pm | #3
    Well,
    you can do it either way, but the three tabs don't have the same warranties that the architectural shingles do. Plus the right ridge caps  have a raised rear portion that keeps the same look that the rest of the shingles have.
    The caps are a little pricey but worth it in the long run.
       Vince Carbone
    Riverside Builders Franklin NY ICQ #47917652
