Are Moisture & Dirt a Problem?
NovusAdGustum | Posted in Construction Techniques on August 4, 2006 08:15am
I recently finished a concrete potable-water cistern for a client. As specified I insulated all the outside walls with DOW extruded polystyrene. I had planned to bring the polystyrene up above the planned final surface and cover it with a stucco. However, to save a few bucks the client and the engineer wish to terminate the insulation about three to four inches below final grade. This leaves about a foot of the cistern wall uninsulated but this “shouldn’t be” a problem according to them as the cistern sits six feet into the ground and holds over 10,000 gallons of water. I generally agree.
However, my question is will the dirt and water that will inevitably get between the wall and the layers of foam be a perpetual problem? I’ve attached a crude drawing. What would be the best way to abate any potential problems?
TIA
  1. peteshlagor | Aug 04, 2006 08:21pm | #1
    How's about gluing a sheet of poly above the foam to drape down over it?
    1. NovusAdGustum | Aug 07, 2006 06:39pm | #2
      Could you recommend an adhesive that is tenacious enough to bond to polyethylene?
      1. peteshlagor | Aug 07, 2006 08:14pm | #3
        The other boys should address this better than I, but I would think any decent construction adhesive would work.
    IMERC | Aug 07, 2006 08:17pm | #4
    use IIRC PL 200 panel board adhesive...
    might be PL300.. it's the blue stuff....
    WOW!!! What a Ride!
