are you needing a work van?
alwaysoverbudget | Posted in Tools for Home Building on March 9, 2009 06:19am
 just thought i’d put this out there if someone is looking for a van.
i have found that the goverment is selling 99-01 dodge vans ,alot of them with 8k-35k miles. they run from about 3k to 5500. at auction. if your needing a van these are pretty hard to beat for that kind of mileage. google gsa auctions to see whats in your area,alot are in the ne.
i looked at a couple with 22k on them,bodies a little rough but drove good in des moines for 2600-3000. ended up buying a pretty nice 1 in st louis ,3/4 ton,23k power windows,locks ,v8 for 3500. seems like it will be alot of transportation for the money. mine 99 dodge isn’t really wore out yet so i’m going to park this one for awhile and put some more miles on it, before i start driving this one.this makes my 4th dodge since 90,had pretty good luck with them with probably a total of 450k miles. larry
YOU ONLY NEED TWO TOOLS IN LIFE – WD-40 AND DUCT TAPE. IF IT DOESN’T
MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN’T MOVE AND DOES, USE THE
DUCT TAPE.
