Armstrong self stick vynil tile.
webby | Posted in General Discussion on October 21, 2009 10:22am
Hey everyone.
I have a potential client who would like to use the Armstrong Crescendo line of self adhesive tile. With this line you get the option of a fitted together look or an actual small 1/8 inch grout joint. This tile is available at Lowes, but I could not find info on it at the Armstrong site.
I am just wondering if anyone has worked with this product before? Any advice?
Webby
    PeterJ | Oct 21, 2009 10:44pm | #1
    Any advice?
    RUN!
    My experience with self stick is that it doesn't..... OK, maybe on a sheet of clean glass, but not in the real world.
    I've heard of people using flooring adhesive in addition to the peel& stick, which I would do if I had to use the stuff.
    Grout joints in vinyl? Regular tile grout? That's a new one to me. I'd be skeptical.
    Can she find no sheet vinyl she likes, gotta be a zillion patterns, just not at Lowe's.
    1. frammer52 | Oct 22, 2009 12:46am | #2
      Grout joints in vinyl? Regular tile grout? That's a new one to me. I'd be skeptical>>>>>>>>>>>>>>>>>>>>
      I actually have seen it, doesn't look bad.  Remember some people can't afford the best material.
    2. barmil | Oct 22, 2009 04:26am | #3
      I don't know about sticking. I used a luan subfloor coated with a sealer before laying the vinyl tiles in a rental, and there've been no adhesion problems. I wouldn't leave any gaps between tiles, however. These were the upper quality tiles, not the ninety-nine centers, and they had little flex. Having flex like the cheap tiles, to me, would be a great contributor to adhesive failure.
  2. cargin | Oct 22, 2009 05:51am | #4
    webby
    I have done alot of peel and stick.
    Never the grouted ones. I wanted a smooth surface without dirt catchers.
    I like to have new subfloor, and then seal with the recommended sealer for peel and stick.
    The stuff I used was a Harvey's product.
    Some boxes stick like crazy and others  seem kind of lame.
    So far I have not had any adhesion issues. But surface prep is the key.
    Rich
      Huck | Oct 22, 2009 06:05am | #5
      that was my thought too.  I've never used the stuff, but a friend did, and it looked ok.  But applying to a clean and flat surface is the key.View Image my website
      1. cargin | Oct 22, 2009 06:12am | #6
        Huck
        I have installed them for a couple of clients and in some rental property.
        In rentals I have been disappointed in the performace of vinyl flooring.
        Renters can really put a gouge in a vinyl floor.
        The peel and stick seems tougher.
        I always think I can just replace one tile, but the big box stores rotate the colors and styles, so you need to keep extras on hand.
        When I tried to replace a tile it was no easy task. I had to use a heat gun to get the old tile lifted.
        Rich
          Huck | Oct 22, 2009 06:17am | #7
          Yup.  That's how you get'm off!View Image my website
        2. DaveRicheson | Oct 22, 2009 01:11pm | #8
          I'm like you.
          I have done several over  correctly prepped underlayment and over concrete. Some were Armstrong and others were what ever flavor a big box had on sales and the client bought.
          Had to take one out that I had installed  20+ years earlier. A sewer line install had cut right through the middle of it and the client was going to refinish the area with carpet. Heat gun and a stiff scapper took it all up. but very slowly. I think that one was an Armstrong job.
          20+ years of life  is pretty good IMO. For the ease of installation and product life, I wouldn't hesitate to install it.
  3. webby | Oct 22, 2009 03:02pm | #9
    Thanks everyone for the input. The client is not sure but may do the peel and stick.
    I have done some peel and stick too, and never had an adhesion problem. However I haven't used these that have the option to grout.
    Thanks again.
    Webby
