Asbestos tile?
gotquestions | Posted in General Discussion on August 30, 2008 07:18am
We started scraping away the current tile in our bathroom and the layer underneath is a black, tar-like layer. In a nearby closet we found a floor tile (either 8×8 or 9×9) that is a black asphalt type tile with a paint-splatter pattern on it and we think this is what that layer is. We also think this is an asbestos tile.  Anybody know for sure?
If so, what are our options? Under the ceramic tile is this black layer substance, then plywood, then the original yellow pine wood flooring.  So these layers are already at a height that is well above the wood flooring in the hall outside the bathroom. I don’t think building right on top of all this is the best idea.
Removal? Can we do this ourselves? Is it a serious threat to try removing it ourselves? What do we do?
    Jeff_Clarke | Aug 30, 2008 07:59pm | #1
    <<  caveat   >>  I am not qualified to identify or deal with asbestos in any way  << end caveat  >>
    It would be more than reasonable to assume that 9 x 9 ALONE in tile size is reason to suspect asbestos.
    This is a professional job - call an abatement co.
    xxPaulCPxx | Aug 30, 2008 08:13pm | #2
    I agree that you probably have asbestos. What concentration, and in exactly which materials specificly makes a difference.  Look in your phone book for industrial hygene labs, they will be able to test samples pretty quick for you.
    Abatement is something you can DIY, but just like working with a table saw you can ABSOLUTLY give yourself and others real injury if you don't work with it correctly and safely.
    Do some research.  After I had an abatement company come out and take care of a bunch of different asbestos issues, I learned enough about the tools and techniques to tackle the other smaller tasks I occasionally run into.
    Also a CRX fanatic!
    I don't feel it's healthy to keep your faults bottled up inside me.
