Ask this old house
DoRight | Posted in Construction Techniques on January 12, 2013 07:31am
Anyone see Ask This Old House this week?  Tom S. had a crack joist to fix.  The jacked it out and used a joisthanger to fix it.  All well and good, but before he jacked it up he put White WOOD GLUE in the crack.  Is that ridiculous or what?
I got a chuckle out of it.
  1. srb2020 | Jan 14, 2013 12:07am | #1
    I didn't see the episode but I'm not sure what's ridiculous about it.  Wood glue joints are usually stronger than the wood itself.  I've repaired plenty of things that way and never seen a failure.
    1. florida | Jan 14, 2013 07:52am | #2
      Ka-zing! From the ridiculous to the sublime in one post!
      If you don't know what's wrong with it you'd probably be better off posting over at This Old House with the rest of the DIY's.
      1. DanH | Jan 14, 2013 08:12am | #3
        It's not clear that the "white glue" was "white glue".  There are many good wood glues that would be indistinguishable from white glue on TV.
        1. florida | Jan 14, 2013 05:12pm | #4
          And once again. Head on over to TOH with  the other Diyers if you don't understand that it doesn't matter what kind of glue he used.
    BossHog | Jan 14, 2013 06:51pm | #5
    It might help keep it from squeeking if nothing else. And it couldn't hurt anything.
    1. DoRight | Jan 16, 2013 01:49pm | #10
      Good point on the squeaking
      That is very likely what was intended.  Good point.  I would have been good of Tom to have mentioned that.
      I think florida would have just used the glue and saved himself a joist hanger, LOL.
  3. DoRight | Jan 14, 2013 08:59pm | #6
    Tha is what Tom said it was
    He said it was white glue.
    It is interesting that there are several sub 60 IQers here.
    Sure glue is stronger than the wood.  That is way when you have a failure it rips the glue and a nanometer of wood off, thus failing right where it did last time.  But it seems several on this thread can not grasp that, how sad for thenm and their clients.
    In addition, he used a joist hanger, you think the joist hanger is the fix in this case?  Ya think?  Then again we have those on thiis thread using duct tape for such a repair.
    I guess I get double laughs from the show.  The silliness of the repair on the show and the show on this thread.  Pretty sad.
    1. calvin | Jan 14, 2013 09:17pm | #7
      why don't you grow up
      please.
    2. rdesigns | Jan 15, 2013 11:18am | #8
      I didn't see the show, but I have great respect for Tom Silva's knowledge and experience. I really doubt he would use a method that wouldn't work.
      Could it be that the split started at the end of the joist where it was maybe nailed into the rim with nails only on the upper half of the joist? If so, a joist hanger would definitely help, and the glue joint would be effective.
      OTOH, if the split happened because of wood grain running to the edge of th joist, I doubt if the glue and joist hanger would help much. Then again, I've got to think that Tom knows at least as much as I do, and would be aware of the the conditions affecting the fix he he chose.
      EDIT:  I was able to stream the show on PBS.org, and it's plain to me that Tom's fix was not primarily the glue--that was just a bit of extra insurance. The real fix was the joist hanger because the joist originally had been notched such that the top half was resting in a corresponding notch in a beam.
      1. florida | Jan 15, 2013 11:25am | #9
        I went and watched the video and think the repair he made was fine. I had assumed the joist was split in the middle.  iBut it was a notched joist that cracked at the notch. He jacked it up and installed a joist hanger under the end attached to the beam. I'm still not sure why he bothered with the white wood glue since it provides no real strength at all. I might do the same thing just to make it look nice but the wood glue had no effect on the structural repair at all.
      2. DoRight | Jan 16, 2013 01:51pm | #11
        Exactly.  The joist hanger.  But some here think it was the glue, and that guy would not step one foot in mmy house.
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
