Attach Allura or Hardie fiberboard siding to cement stem wall
user-389891 | Posted in Construction Techniques on April 28, 2019 05:12pm
How do I do it?  Siding to concrete? The siding may need to be firred out with foam or wood to match existing siding?My garage was built in the mountains using a stepped stem wall on 2 sides because the land is sloped. My contractor installed Allura siding from the roof down but left a jagged checkerboard bottom that runs from 6″ to 12″ above grade. It look terrible. He says paint the concrete or add a stone bottom. Bottom line, he is dogging the job imo as I already paid him for the finished product. So how do I do it? I can’t glue it because it would be recessed from current siding. Side note: I am trying to be an owner builder which not I realize was a mistake but I am stymied on this last piece to make my garage presentable.
    tfarwell | Apr 28, 2019 06:07pm | #1
    My neighbor just attached Hardie plank to a stem wall on their house last month. I suggested using tapcons to attach 3/4 PT plywood strips and nailing to that. She didn't like the idea of it sticking out, so she screwed it directly to the concrete with tapcons every two feet. I had to loan her my hammer drill and a good bit to drill all those holes. It took her a bit of time, but turned out looking just fine.
    1. florida | Apr 29, 2019 01:06pm | #4
      Fur it out with 1 X 4" pressure treated strips. Attach them with stainless steel concrete screws. don't use the blue ones as they rust away pretty quickly. Attached the siding with 1 1/2" roofing nails. Also, remember that the siding can't touch the ground. You might need to use a PVC trim board at the bottom.
  2. DanH | Apr 29, 2019 07:50am | #2
    I wouldn't attach fiberboard siding directly to concrete. Definitely fir it out with something, so that the fiberboard is not exposed to the moisture in the concrete.
  3. Alexaeon | Apr 29, 2019 09:36am | #3
    same question i also have
  4. MattMillham | May 02, 2019 03:04pm | #5
    Agree with DanH. You'll want to check the installation manuals for both products. Neither is rated for contact with concrete or masonry and should not be attached directly to it. I believe instructions for both require a 6-in. minimum clearance from finished grade. You might want to check out Boral's TruExterior products, which (as far as I know) are rated for ground and masonry contact.
Fast, Accurate Wall Framing
