Attaching a 4×4 sill to concrete
| Posted in General Discussion on June 2, 2003 07:08am
I was wondering what is the best way to attach a PT 4×4 sill to a concrete pad for a small outbuilding.  The building is a well house.  Thanks
Tom
  1. xMikeSmith | Jun 02, 2003 07:30pm | #1
    best and easiest is cast-in-place foundation bolts  (J-bolt ), say 1/2 x 10..
    if the slab is already poured... drill and set epoxy foundation bolts...
    Mike Smith   Rhode Island : Design / Build / Repair / Restore
  2. Gabe | Jun 03, 2003 02:33am | #2
    You can also get 3/8 and 1/2 inch bolts that screw directly into a drilled hole just like Tapcons.
    Saves a shiitload of work. No inserts and no epoxy.
    Gabe
    1. xMikeSmith | Jun 03, 2003 03:27am | #3
      gabe , how did you get #### past the censor ?  do you know someone ?Mike Smith   Rhode Island : Design / Build / Repair / Restore
      1. Gabe | Jun 03, 2003 03:52am | #4
        I know people.......................:)
        Gabe
      2. timkline | Jun 03, 2003 07:08am | #6
        shiit, shiiit, shiiiit.      sheeeeeeeet  !
        tihs............it's all done with mirrors.......................!
        carpenter in transition
        1. xMikeSmith | Jun 03, 2003 02:13pm | #7
          right.. but gabe blew that 1 right by me...
          kinda like toronto derailing the red sox train..Mike Smith   Rhode Island : Design / Build / Repair / Restore
          1. Gabe | Jun 04, 2003 12:10am | #8
            Mike you might want to check out http://www.powers.com/
            regarding wedgebolts.
            Kinda like a king sized tapcon. One shot installation.
            Later
            Gabe
          2. xMikeSmith | Jun 04, 2003 02:06pm | #10
            gabe.. i've used 'em all... but thanks for the link..
            so far... for sills in existing conc. i like the epoxy bolts....but each situation usually gets a different solutionMike Smith   Rhode Island : Design / Build / Repair / Restore
  3. junkhound | Jun 03, 2003 05:15am | #5
    Well, duh, for a well house  -  just glue it down with drywall or subfloor adhesive, unless you got some code weenie on your tail.
  4. Davo304 | Jun 04, 2003 07:17am | #9
     Ditto what Gabe said about using wedge bolts.
    However, if you cannot find this type, you could use "quick-bolts" instead...they are a concrete anchor that has a nut & washer on top and an expanding sleeve  attached to the bottom of the bolt. Drill your hole, pound the sleeve anchor into the hole, place the nut & washer back on top, and tighten down with a wrench. These normally hold really well.
    Davo
