Attaching a deck
Flaherty | Posted in General Discussion on June 30, 2008 05:26am
We have a house with a walkout basement and want to put in a deck off the main floor (i.e. 1 story up).   The exterior walls are clad in brick.  When attaching the legder board to the house do I have to go right through the brick and the framing to bolt it on or can I just use lag bolts and go into the brick?
Any advice is appreciated.
  1. plumbbill | Jun 30, 2008 05:46am | #1
    Bricks have no flexibility to them, so when there is movement on the deck it will crack the mortar & pull the bricks out.
    You need to anchor to a structural support, so yes drill through the bricks & anchor to the framing inside.
  2. Piffin | Jun 30, 2008 05:57am | #2
    I'd use another set of posts and beam near the house to avoid penetrating th e brick veneer
      Dinosaur | Jun 30, 2008 07:58am | #3
      Yeah, but that means he'd have to build a free-standing structure not attached to the house at all. Lotta extra framing to keep it from racking/swaying, seems to me.
      Or are you talking about my Velcro¯ idea again...?
      Dinosaur
A New Approach to Foundations
