Attaching cross braces
gollygeewhiz | Posted in Construction Techniques on November 20, 2014 02:18am
I’m building a post foundation home in Alaska, but had a question on the cross-bracing for the posts. I’ve not built a deck or a foundation this way before, and I was wondering if anyone had tips on attachment. I would assume you’d want AT LEAST some decking screws (4 or 5 per connection) to attach the bracing to the posts, but I’m open to hear what’s overkill and what’s necessary to provide strength and safety. I seem to find everything from “use 3 lag screws in each” to “just put in a few #20 nails.” What are your thoughts? Thanks in advance.
6x6x10 posts, 2x6x8 cross-braces. All treated wood for the maribe exposure.
  1. DanH | Nov 20, 2014 06:17pm | #1
    "Cross braces" covers a
    "Cross braces" covers a multitude of sins, from temporary lightweight bracing used during construction to heavy duty stuff that's intended to withstand earthquakes.  Often a post foundation, if the posts are buried sufficiently, needs no cross-bracing, but in other cases, especially when the elevation is significant, the bracing is critical.
    I think folks need to know a bit more about your particular situation.
  2. mark122 | Nov 20, 2014 07:03pm | #2
    Yeah a little more info on how the foundation if built would help know how to give suggestions based on experience, if i were you i would shoot for overkill and not the minimum. Carriage bolts or lag screws would probablly be my choice.
    deadnuts | Nov 20, 2014 10:24pm | #3
    how open?
    gollygeewhiz wrote:
    I'm open to hear what's overkill and what's necessary to provide strength and safety.
    Are you open to it if that advice comes from a P.E....along with a fee for service? Because if your permit set of plans do not specify the necessary strucutural connections for your post foundation home (and I don't understand why they wouldn't), then that's where the qualifed advice should come from. Other than that, all you're going to get here is dart board throwing--as evidenced already.
  4. mark122 | Nov 21, 2014 08:15am | #4
    What part of alaska? ill be up there next season for some game chasing...look forward to it.
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
