attaching deck boards from below
| Posted in General Discussion on August 19, 2002 04:55am
Hello all,
I am adding a deck to the front of my house.  Since it is a post & beam house I figured I might as well make it a post & beam deck.  I am using locust for all the structural parts.  I mill each piece from a log on a woodmizer mill.  The joists are 8 by 6.  Each end is secured with a housed dovetail.  I am using pau lupe for the decking.  I don’t want to surface nail.  After looking at the different deck clips or deck ties a friend of mine suggested the following idea.  Attach a 1 by 10 (pressure treated) to the top of each joist running parallel to the joist.  This would leave 1 3/4″ extending on each side of the joist.  I would then screw the deck from below through the 1 3/4″ overhang.  This is just as easy as any of the deck clips on the market.  The only disadvantage is that the deck is now 3/4″ higher.  Does anyone see a problem with a board as wide as a 1 by 10?  Would pressure treated plywood be better?  Does anyone see any problems with this idea?
  1. agent101 | Aug 19, 2002 05:12am | #1
    Is the porch going to be covered? I think a 9 1/4" joist is inviting a few water issues. If the porch is not covered, you may try putting an Ice and Watersheild or flashing over the joist and then fastening with EB-TY's.
  2. MarkH128 | Aug 19, 2002 05:15am | #2
    3/4 pressure treated lumber splits easy, and you could create a moist environment with that wide of an overlap. Pressure treated plywood might be better suited, but also might delaminate over time. I would consider using a product made for this application myself. The locust should last about forever, so you should try to find a solution that will be very durable.
A New Approach to Foundations
