Attaching deck ledger to block wall
any ideas or suggestion on how to attach a ground level deck ledger to a concrete block wall.
Check with an engineer- but I have seen holes drilled through the block
wall to go through metal plate the length of the deck. You then
sandwich the block between the outside ledger board and flashing and the
metal plate inside (with thru bolts and locknuts)
But first, describe the house framing on top the block wall; got a rim
joist or not? Maybe a little more detail on the project.
i would like to build it independenly but the sewer line run along the house next to the wall. the whole first floor is concrete block so a there is no rim joist. there is an existing covered porch over where this deck will be built. also the inside of the block wall is finished room so through bolts are out of the question. thanks for all the ideas.
You can set the posts 2' in from the outside wall of the house (or more) depending on the joist or beam size/span.
http://www.peteforgovernor.com
I second Pete on pulling the posts/beams away from the block wall and cantilevering the joists up to the block wall. 2x8 joists will cantilever 18" - 24" over the beam as long as the total length of the joist is longer than 6'. Keep this deck freestanding.Mac
Do not repeat 'not' use Tapcons. They are too brittle and will snap sooner or later. More likely sooner....
You have a choice of drilling between two courses of block and using lead anchors and lag screws (5/16"x3"); or of drilling into the cavities in the block and using toggle bolts. Don't try to use short expanding anchors of any type in the 'skin' of the block; they'll crack it when you crank down on the bolt or lag screw.
Dinosaur
A day may come when the courage of men fails,when we forsake our friends and break all bonds of fellowship...
But it is not this day.
Drill all the way through the block wall and use 3/4" machine bolts at 24" centers staggered with large square washers. Do not use lags or lead shields. If you have snow loads or impact loads then consult an engineer.
If it is a ground level, why attach to the wall at all? Unless you just want some superficial attachment to keep a gap from forming between the house and the deck. If that is the case, just about kind of screw/anchor intended for the purpose will work. Drill into the mortar joints - either the horizontal or the vertical ones.
Either that, or maybe you are in earthquake country?
One solution which came up during a church remodel when we had to attach the floor of the new pastor's office to a hollow core block wall (and thank God for the engineer there) was using an epoxy "umbrella" anchor. The way it works, you drill the hole, stick the umbrella thing in, the back expands not unlike a molly, or something in your girlfriends drink, you pump it full of epoxy and set your allthread in it. Cure time, then bolt on the ledger. Worked pretty slick.
i use this type of stuff all the time. we use it for pretty large forces. i think if you read the specs it will be more than enough for you.
http://www.us.hilti.com/holus/modules/prcat/prca_navigation.jsp?OID=-12139
Tmaxxx
Urban Workshop Ltd
Vancouver B.C.
cheers. Ill buy.
The best way to attach a ground level deck is to not attach it.
unless there is a great reason for it, I always build my decks as independent structures. I never attach them to the house and do not recommend that anyone else should either.
